Coke Tab Bracelet
Intro: Coke Tab Bracelet
Difficulty: Complex
-Some level of crafting skill required
Time: Approximately 30 minutes
-Not including time to decorate
Safety: Overlap tabs so you do not cut skin
STEP 1: Gather Materials
You will need:
Elastic string (any color)
Soda tabs (at least 20)
Scissors
Sharpies or nail polish (used to decorate)
-If you wish to decorate bracelet, paint soda tabs with sharpies or nail polish before putting bracelet together. The tabs will need time to dry.
STEP 2: Remove the Small Ring That Holds the Tab to the Soda Can
STEP 3: Take String and Loosely Wrap It Around Wrist 4 Times
STEP 4: Cut String
STEP 5: Lay Tabs Back to Back. Smooth Sides Are on the Outside and the Same Size Holes Should Align
STEP 6: Fold String in Half
STEP 7: Thread Each End of the String Through a Separate Hole
STEP 8: Move the Soda Tab So It Sits in the Center With Equal Length of String on Each Side
STEP 9: Pull String to the Side So It Is Out of the Way
STEP 10: Place a Coke Tab on Top of the Coke Tab Used in Steps 6-8, So Rough Sides Are Touching and the Similarly-shaped Holes Are Aligned
STEP 11: Loop the Top String Through the Top Holes & Loop the Bottom String Through the Bottom Holes
STEP 12: Flip Bracelet Over
STEP 13: Pull String Out of the Way
STEP 14: Add Another Tab So That It Lies Next to the First Tab and on Top of the Second
STEP 15: Thread String Through Both Opposite Holes. (top String Through Bottom Holes and Bottom String Through Top Holes So That It Makes an X)
STEP 16: Pull String Tight So That It Looks Like Picture
STEP 17: Repeat Steps 11-15 Until Desired Length Is Achieved, Leaving a Little Extra String in Order to Tie End Knot
STEP 18: Thread String Through the End Tab Same Holes (so That the Bottom String Goes Through the Bottom Hole and the Top String Goes Through the Top Hole)
STEP 19: Repeat Step 14 to Combine the Two Ends of Bracelet
STEP 20: Tie a Double Knot on Inside of Bracelet
STEP 21: Cut Off Excess String
You have now completed your coke tab bracelet!
