Cold Process Liquid Soap
Intro: Cold Process Liquid Soap
Want to make liquid soap, but don't want to spend hours laboring over a hot crock pot? Well, this might be a great alternative.
It's not a fast process, but it's nice to mix it up and let it sit while you tend to other things.
STEP 1: Mix the Lye With the Water
**Before attempting this process, please make sure you are very well versed on lye safety. Read all safety information on the container, in the material safety data paperwork from the manufacturer and follow all safety guidelines.**
Mix a little Potassium Hydroxide at a time into the water and stir. Be careful as Potassium Hydroxide can be more volatile to work with than sodium hydroxide. Make sure not to use an Aluminum Container as it can react with the lye and try to avoid glass containers which have been known to shatter.
Do this in a well ventilated area.
STEP 2: Mix the Lye With the Oils
Using a blender or stick blender, mix the oils and lye together in a lye safe bowl (this is usually a container with #5 or a Stainless Steel pot that can be covered). The first picture is just after mixing the first time.
Cover the mix with a lid or plastic wrap where air cannot get to the mix and set it aside for about an hour.
STEP 3: Hour One
Mix again and let it rest for about an hour. This is what mine looked like after the second mix.
Did you know during this time, you could knock out a cold process bar soap? I have a tutorial for that too. :)
STEP 4: Hour Three
At about hour 3, I mixed again and it reached what is called the Mash Potato stage. Cover and let it sit some more. This is what mine looked like after the third mix.
STEP 5: Final Step Before Letting It Rest
In this picture, this is about a half hour later and another mix. At this point, cover and let the mix rest overnight or longer in a cool dark place.
STEP 6: Paste Complete
I let this sit for more than 6 months. It is now considered a paste.
You will want to test the mix to ensure the lye is no longer active before moving on to diluting the mix to make the final liquid soap product.
There are several resources out there to help you with testing such as this video with Kevin Dunn for the Soap Guild https://www.youtube.com/watch?v=Hone0KqVUI8.
STEP 7: Dilute to Make Liquid Soap
I diluted the soap paste in water in a one to one ratio (2 ounces of paste to 2 ounces of distilled water). You can adjust the amount of water to paste to get the desired consistency and that's it.
If you want to add fragrance, be sure to follow IFRA safe usage rates. Most fragrance oil and essential oil suppliers provide this information to help you fragrance safely.
Happy soaping.
