Collapsible Bucket
Intro: Collapsible Bucket
A simple fabric bucket that has been designed to be rigid enough to stand on its own, yet pliable enough to be folded for easy storage.
The use of heavy-weight fabrics, rather than paper-like interfacing, allows for great recovery even after folding/storage.
Etsy Sew Useful Listing
http://www.etsy.com/view_listing.php?listing_id=6215452
STEP 1: Recommended Fabrics
Duck, heavy twill, drill, canvas, denim
STEP 2: Material List
Choose 2 coordinating fabrics at least 45" wide.
Fabric #1 3/4 yard
Fabric #2 1/3 yard
Buttons, 2 or 3 or 4. Vintage or new. Matched or not.
Fabric #1 3/4 yard
Fabric #2 1/3 yard
STEP 3: The Pattern
(Top to bottom in photo)
Lining. 29.25" x 9.0" Cut 1
Shell A. 29.25" x 6.5" Cut 1*
Shell B. 29.25" x 3.5" Cut 1
Handle. 24" x 2.5" Cut 2
Base. 9" diameter Cut 2 (trace a pie plate or dig out that compass)
Note: Lining, handle, base, and Shell B are all the same fabric. The only contrasting fabric I use is for Shell A.
*modifications for Shell A. If you opt for a light or medium decorative fabric, interface with a layer of duck. I recommend sewing/basting decorative fabric to duck, rather than an iron-on interface. It provides an easy and informal look to the bucket. It also minimzes fold lines later after bucket has been stored.
STEP 4: Assembly; Shell
Handle:
~1/4 inch seam allowance.
~Sew right sides together,leave one end open, turn, topstitch. I personally prefer to do the button holes last only because I generally can't pick buttons before hand.
Shell:
~1/2 inch seam allowance.
~Fold Shell A in half length-wise and sew right sides together, press open seams.
~Repeat for Shell B.
~Face (right side to right side) Shell A & B making sure that seams line up. (photo #1)
~Insert unfinished end of strap between both shell pieces assuring that it's centered.(photo #1)
~Sew together. 1/2" seam allowance. (photo #2)
~Unfold and press seams flat (photo #3)
~Topstich (photo #4)
Shell:
STEP 5: Assembly; Shell Wall to Shell Base
Joining shell base to shell wall:
~Mark the quarters on the circle with pins.(photo #1)
~Do the same with the shell wall.
~Match up quarter marks on base and wall, pin together. Gently ease pieces together adding more pins. (photo #2) *note. I can about guarantee that these pieces will not fit together if you don't "pre-ease" using pins, so do this step even if you hate pinning. I strongly dislike ripping seams. lol.
~Sew right side to right side.
~Trim closely or snip seam allowance. (photo #3)
tips: I sew so that the base is being fed with my feed dogs. Some people are more comfortable having the dogs help the ease of the walls along. It's all a preference and I don't know that one is more correct.
STEP 6: Assembly; Lining Wall
Lining wall:
~Fold in half length-wise, right sides together, sew together but leave open at pin marks in photo. This is where you'll pull the bucket right side out later.
STEP 7: Assembly; Lining Wall to Base
Adjoining lining base to lining wall:
~ Right sides together.
~Repeat instructions from step #5.
STEP 8: Assembly; Joining Lining to Shell
Joining lining and shell;
~ 1/2 inch seam allowance.
~Right side to right side, making sure handle is tucked in, sew together. (photo #1)
~Turn bucket out through the opening you left in the lining.
~Press as needed
~Top stitch where lining meets shell, catching the handle in the topstitch.
~Use a ladder stitch to close opening in interior. (photo #2)
~Press as needed
STEP 9: Adding Buttons and Buttonholes
Buttons and buttonholes: Decide size and placement. I like to have the end of the handle rest right at the top of the bottom of exterior.
I'm leaving this up to artistic expression, maybe you want to run 6 buttons up the side.
STEP 10: Fold It Up
~Unbutton handle
~Collapse one half into the other half with handle on top. (photo #1)
~ Fold bottom up flat (photo #2)
~Fold in each side to the center and fold the handle down over folds, flip, and button. (Photos # 3 and 4)
~Stuff in your back pocket and head to the garden or yarn shop to lug out your bounty.
19 Comments
Laurie in Maine 16 years ago
Deeluxcious 1 year ago
ravenarelics 15 years ago
786Ayesha 10 years ago
frogangel 15 years ago
Dalya 16 years ago
mycroftxxx 16 years ago
princessbunnyrooroo 16 years ago
worldzend 16 years ago
woolfood 16 years ago
mymsie 16 years ago
Lucky Bear 16 years ago
jkluit 16 years ago
jrodehickey 16 years ago
SoftAscent 16 years ago
trinit 16 years ago
mrmath 16 years ago
