Color Up Your Xbox 360 Controller!
Intro: Color Up Your Xbox 360 Controller!
In this instructible i will teach you how to color you xbox 360 controller with sharpies (that what i used) or spray paint. Its quite simple really.
WARNING- In this instrucitble you will need to take apart your xbox 360 controller. Doing this you void your warranty with Microsoft.
STEP 1: Take It Apart!
Okay to take apart the Xbox 360 controller you will need a torex 8 screwdriver. (but you can actually get away with using a small flat head). There are 7 screws located on the controller. One is under the sticker where the batter pack is.
STEP 2: Gut It!
Now that you have it taken apat gut it out! take everything and put it somewhere safe.
STEP 3: Design.
Okay you now how two options. You can Draw you own design on it or can can spray paint it a boring color. If you decide to spray paint it the go to the next step.
Okay those who decided to color it and make awesome designs then you need these:
Clear Coat -can be found home depot, lowes etc.
Permanent markers -I used the Bic brand because i like the colors, but sharpie will work fine as well.
"Painters Tape" -A blue colored tape that is used to cover stuff that you do not want to tape.
STEP 4: Tape It Up.
IF YOU ARE GOING TO SPRAY PAIN I T THEN LOOK AT BOTTOM.
Okay once you done with you awesome design markers the you need to tape it up. To tape it up you need to cover all hole because you do not want the clear coat to be in there the buttons are because it would then get sticky.
If spraying then get it taped up ahead of time and spray and then clear coat it.
STEP 5: Clear Coat It !
Now that it is taped up. And you design is all done, you now need to take you controller part and place it on newspaper and spray it with clear coat. I would suggest 3-4 coats of it. You will know when its ready because it will be shinny.
SPRAY BACK AND FORTH SO IT WILL NOT GLOB UP!
STEP 6: After It Drys.
Remove the tape and put it back together! Once back together test all buttons and if some are sticky then take it apart and scrape around the holes with a knife.
83 Comments
chnynnpsttxix 8 years ago
ahmedabutahoun2003 8 years ago
Hmm, nice but how to tape it? Also, is there a way to custom mode (color up) the controller without opening the controller? Because I have sees some with paper (you print the body on paper then draw on it then stick it on the controller) (BTW nice style)
AlluringAngel 10 years ago
beauwalker23 10 years ago
smusso 12 years ago
khsora 11 years ago
kwilson11 12 years ago
c0deater 12 years ago
thegamer01 12 years ago
jrodriguez49 12 years ago
neo-sky 12 years ago
bhitson 12 years ago
IamSASORI 13 years ago
inforussle 13 years ago
SanguineVisions 13 years ago
sumner072 13 years ago
beauwalker23 13 years ago
