Command Prompt Matrix NUMBERS
Intro: Command Prompt Matrix NUMBERS
My last Instructable with the Matrix was only with the letters, but this one is a batch file that uses numbers, and looks more realistic. The real Matrix used Japanese letters and other symbols, but this one just uses numbers in different orders and sizes and it looks more realistic from my last Instructable.
It is pretty easy so lets get to it.
STEP 1: What Technology Do I Need?
You need:
- PC with command prompt
- The notepad application
- The code I will give you
STEP 2: The Code
Ok, to enter the code, you have to open the Notepad.
Enter this code:
@echo off
color 0a
:top
echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
goto top
Enter this code:
@echo off
color 0a
:top
goto top
- Make sure the %random% is in one line across the screen, don't let it go to another line.
STEP 3: Save It As .bat
Save the notepad file on to your Dekstop as a .bat file.
Save it as:
matrix.bat
You have to have the .bat at the end for this to work, because .bat is batch and batch is used with the command prompt.
Save it as:
matrix.bat
STEP 4: Open It and Let It Run
Open it on your desktop and let it run!!!
Show it to your friends and watch them be amazed.
STEP 5: Making Screen Bigger
If you want to make it full screen, right click on the top blue bar, and click properties.
Choose layout, and change the height and width of the window size to 300. If you want to make the 300 default, right click on the top bar again, choose defaults, choose layout again, and make the height and width 300.
Keep in mind:
Have Fun!
Keep in mind:
- If you make the screen bigger, you will have to add more: %random% to the code.
Have Fun!
88 Comments
Lexoguy_ 8 years ago
This does not work for me.
Probably because I'm on windows 7.
maleboyf 7 years ago
echo off
:top
start start
goto top
DannyRichie 4 years ago
I have a loyal Compooter 6 years ago
i had to reboot my pc after this
nice trap bruh
and name it BEST GAME EVER
you can try mine
ErlonM 8 years ago
Try use mine batch file...
ErlonM 8 years ago
@rem - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
@rem Try USE it in Win7 i made it... Running well... cya
@echo off
set cmd_l=Call %0 Cmd_list
color 0a
if not (%1)==() goto %1
:begin
title Loading...
set word=
%cmd_l% 6
for %%A in (W a k e × u p ' × N e o . . .) do call %0 Wsentence %%A
set word=
%cmd_l% 8
for %%B in (T h e × M a t r i x × h a s × y o u . . .) do call %0 Wsentence %%B
set word=
%cmd_l% 6
for %%C in (F o l l o w × t h e × w h i t e × r a b b i t × Neo.) do call %0 Wsentence %%C
set word=
%cmd_l% 6
for %%D in (K n o c k ' × k n o c k ' × N e o .) do call %0 Wsentence %%D
set word=
%cmd_l% 3
rem echo
title Loading Matrix...
echo @echo off>"%tmp%\loop.bat"
echo title Matrix>>"%tmp%\loop.bat"
echo mode 1000,150>>"%tmp%\loop.bat"
echo :random>>"%tmp%\loop.bat"
SET Write_rnd=SET /a rps=%%RANDOM%% * 2 / 32768 + 1 %
echo %Write_rnd%>>"%tmp%\loop.bat"
echo if (%%rps%%)==(1) color 0a>>"%tmp%\loop.bat"
echo if (%%rps%%)==(2) color 02>>"%tmp%\loop.bat"
echo SET /a uline=%%uline%% + 1 >>"%tmp%\loop.bat"
echo if (%%uline%%)==(90) title Matrix_>>"%tmp%\loop.bat"
echo if (%%uline%%)==(90) set uline=00>> "%tmp%\loop.bat"
echo if (%%uline%%)==(40) title Matrix>>"%tmp%\loop.bat"
SET Write_rnd=
for /l %%Y in (1,7,3000) do call %0 Mnt_Random %%Y
echo echo %Write_rnd%>>"%tmp%\loop.bat"
echo goto random>>"%tmp%\loop.bat"
start "" /max "%tmp%\loop.bat"
goto end
:Mnt_Random
set Write_rnd=%Write_rnd%%2%%random%%
goto end
:Wsentence
if not (%2)==(') if not (%2)==(×) set word=%word%%2
if (%2)==(×) set word=%word% %
if (%2)==(') set word=%word%,
if (%2)==(×) color 02
if not (%2)==(×) color 0a
if (%2)==(y) ping 127.0.0.1 -n 1 >nul
if (%2)==(x) ping 127.0.0.1 -n 1 >nul
if (%2)==(r) ping 127.0.0.1 -n 1 >nul
if (%2)==(u) ping 127.0.0.1 -n 1 >nul
if (%2)==(h) mode >nul
if (%2)==(.) ping 127.0.0.1 -n 1 >nul
cls
echo %word%
title %word%
%cmd_l% 1
goto end
:Cmd_list
if (%2)==() ping 127.0.0.1 -n 1 >nul
if not (%2)==() ping 127.0.0.1 -n %2 >nul
goto end
:end
PANSILUB 5 years ago
this is good
MattMaletto 4 years ago
TheColorMaster 4 years ago
@echo off
mode con: cols=187 lines=44
color a
: colorful
title
echo [90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m
title C
echo [91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m
title CO
echo [92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m[91m%random%[0m
title COO
echo [93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m[91m%random%[0m[93m%random%[0m
title COOL
echo [94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m[91m%random%[0m[93m%random%[0m[92m%random%[0m
title COO
echo [95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m[91m%random%[0m[93m%random%[0m[92m%random%[0m[94m%random%[0m
title CO
echo [96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m[91m%random%[0m[93m%random%[0m[92m%random%[0m[94m%random%[0m[95m%random%[0m
title C
echo [97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[97m%random%[0m[90m%random%[0m[91m%random%[0m[92m%random%[0m[93m%random%[0m[94m%random%[0m[95m%random%[0m[96m%random%[0m[90m%random%[0m[91m%random%[0m[93m%random%[0m[92m%random%[0m[94m%random%[0m[95m%random%[0m[97m%random%[0m
goto colorful
@echo off
title Matrix\
msg * Please Wait While The File Opens!
msg * please click ok to process!
msg * ready to hack!
msg * You Will be hacked!
msg * I Will erase you hard drives!
msg * SORRY!
pause
echo !CLICK TO ANY BUTTON!
pause
color 5E
mode 1000
:matrix
echo %random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%
goto matrix
KyleK87 7 years ago
noice
FunLife3315 7 years ago
O.M.G
FULL VERSION
Alone boy 26 8 years ago
title Matrix\
msg * You May Now Click OK!
msg * You Just DownLoaded Porn!
msg * I Will Find You And Eat You!
msg * Please Press Enter Twice!
pause
pause
color 5E
mode 1000
:matrix
goto matrix
JosephO27 8 years ago
Damn N00B^ You dont know how to properly make something here you peeps go :)
@echo off
title Matrix\
msg * You Just Downloaded Porn!
msg * You Will Be Hacked!
pause
pause
color 0a
mode 1000
:matrix
goto matrix
JosiahM7 8 years ago
THX maNG
virgile1 8 years ago
noobs
