Introduction: Compact CNC/3D Printer
Hi friend’s I'm coming with new project was A Compact CNC/3D
printer that was build using waste parts.
First of all personally thanks to Gelstronic who help me for technical support .
This printer totally open source and made using waste parts from CD/DVD writer, Arduino, L293D motor shield and some other tools.
Step 1: Hardware’s/Components:-
CD/DVD drives
Aluminum Sheet
Arduino Mega 2560
L293D stepper shield
And some other parts:-
-Some nuts, screws and washers
-Thermocol sheets
-Some jumper wires
-Pic of fiber glass
Step 2: Dimension and Blue Print for Metal Sheet
This Photo gives you size and dimension of my metal sheet that used for attached CD/DVD drive for configure or make correct axis plane. And its also give the pinout of CD/DVD drive stepper motor for connect right pin with shield.
Step 3: Make Model:-
Take metal sheet and mark all dimension and cut it with
right dimension and drill the holes to connect CD/DVD drives[make sore that dimension that I give it follow my hardware so take your drives and make right measurement on metal sheet before cutting/drilling].
Step 4: Now Assemble All Axis X, Y and Z Axis on Metal Sheet.
Step 5: Complete All Aixs, Base and Wiring
solder all wires and jumpers as per need to connect CD/DVD ROM
Step 6: Checking the First CNC With Open Hardware
First check that your all printer axis correctly work or not, after than go for next all steps.
Step 7: Now Connect With #~#Arduino and Upload #
Now make all that things with Arduino Mega-2560. for fully automated CNC/3D Printer, here circuit diagram given for the connection between arduino and all steppers. And its source code file also given that's based on tonokip firmware.
Step 8: Prepare for Design Your Printer Cover BOX
This model designed in Google SketchUP software thats free.
All post its .SKP file here, thats dimension doesn't matched but its also useful for planing only.
Step 9: Make BOX for Cover It
I made a cover box for my CNC/3D printer that really protect plu give nice look the Printer.
Step 10: Make With Amazing Stickers
Step 11: Completing Box and Final Printer
Now put your all hardware into the Box with complete accessory your all ROM's and Arduino board too into the box.
Step 12: Continue With Testing Printer
Step 13: How to Setup Repetier Host and Slicer Setting
In this zip file you will get all configuration and settings photos of Repetier-Host software and Slicer settings too.
That help to setup and configure both these software easily
Soldering Challenge
Metal Contest
37 Comments
3 years ago
Nice, but this thread and its title look like it is want only collecting gaining viewership, or this is advertising sth? All in all, this is not quite 3D printer. Nothing been stricte print to really 3D element, only 2D drawing. Topic without preciselly clues. Printer cover box and amazing stickers, less interested things for me. Weak stuff, wasted time.
Reply 3 years ago
Okay,
Thank you... :)
6 years ago
Hello, what the OS used to use it as a method of 3D printer? I was thinking about doing a project for summer.
Reply 6 years ago
Hi,
If you ask for PC - OS then i perform it on Windows 7...
6 years ago
Hi brother !
Your videos are very helpful !
I need some help from you personally , I'm an mechanical student so don't know about programming, will you please help me to program in Aurdunio app to Controll the mini 2D cnc ?
Reply 6 years ago
Thanks You bro :)
8 years ago
Movie?
Reply 6 years ago
will go soon :)
8 years ago on Introduction
Compact indeed.
Seen this idea before but keep loving it. Nice.
Reply 6 years ago
6 years ago
Is it possible to add a laser and cut stuff with it?
Reply 6 years ago
Yes but obviously, we can use it as laser cutter too. :)
7 years ago
3D ??? where it is, its plotting 2d, correct me if i am wrong or i missed something....!!
7 years ago
Means u are using the 3d pen and instead i want to use a pencil which can draw figures. Possible?
Reply 7 years ago
Yes Brother......
For Drawin you can use its can work like a full CNC Drawer
7 years ago
Shall we use this machine for mechanical drawings?
Reply 7 years ago
Yes you can i.e.-Orthograph
7 years ago
7 years ago
For four electric motors are needed? 2 is sufficient and one mini servo lifting as you paint only. In fact it is rather a plotter at this stage, not a printer or CNC. However, the pen can be substituted for example with one of those 3D pen.
7 years ago
good
