Compact Disc Organizer
Intro: Compact Disc Organizer
I needed an organizer for compact discs for a cabinet I was building and none of the off-the-shelf ones I saw fit my requirements. Naturally, I did what any full-blooded Instructabler would do: I built my own at the Tecshop, http://www.techshop.ws. The overall dimensions were fixed by the shelf available and I wanted to maximize the space I had to work with.
STEP 1:
The first order of business was to measure a stack of five CDs in standard cases. I added a bit to the width and a scoatch to the stack depth and that established the "pocket" size. I had decided to use 1/4" MDF for the four sides and two column dividers and 1/8" MDF for the row partitions. After hand sketching my plans I did the parts layout in a 2D graphic program I have used extensively, DeltaCad 8. The finger joints, interlocking slots and slot and & tab dimensions were based on the material dimensions.
STEP 2:
Just for giggles I reproduced the part layout in SketchUp to do a fit check.
STEP 3:
I imported my DeltaCad drawings into Corel for the actual laser cutting layout. Someone is going to ask why I didn't just use Corel to start with. The answer is that I am more familiar with DeltaCad and that's where I started the layout.
It turned out that everything fit onto four 24" X 18" pieces. There was even room for the fit-check pieces shown in the next step.
STEP 4:
Before I cut the whole shootin' match, I made a test set of the joints. It turned out that things were a bit tight. That's not a good thing when there are this many pieces that need to go together. Once the corners are glued, the assembly is plenty rigid, so it's better to be a bit on the loose side for the sake of assembly.
I went back to the Corel layout drawing and "loosened up" the interlocking slot and tab & slot joints.
STEP 5:
Assemble the pieces for a fit check.
STEP 6:
After spray priming and painting all the pieces flat black, I used five minute epoxy to bond the four outside corner joints. That is all that is really necessary.
STEP 7:
The organizer is epoxied into four holes drilled part-way through the shelf.
4 Comments
Crafty Milt 4 years ago
1. What is MDF? (This will expose my ignorance!)
2. How did you do your laser cutting? Can you recommend some way to accomplish this for a novice do-it-yourselfer? I’m actually a retired laser/optical engineer but 76 now and have lost all my work contacts. Thanks, Milt
togo1919 11 years ago
Are you planning to design one of these for your 33s and 45s?
bgerens 11 years ago
Penolopy Bulnick 11 years ago
