Concrete LED Light Cube
Intro: Concrete LED Light Cube
This concrete LED light cube is very simply, yet pretty striking and I think it would make the perfect accent or night light. Concrete is so much fun to use, and of course you can vary the design depending on your preferences and add color, change the size of the molds - whatever. It's a pretty easy project and you don't need too many tools to work on it!
STEP 1: Electronics
For this project I'm going to be using these 5 volt led strip lights. These are really cool because you can power them with a common 5 volt phone charger. Here's a regular 12 volt led strip on the right for comparison, and there we have three lights in series and every connection is a parallel connection, whereas on the 5 volt strip they are all parallel with only one light and resistor per section.
STEP 2: Micro USB
I'm going to be using a micro usb, and these are really tiny. This is what you need so you can plug any phone charger in. Now, these have multiple pins because the middle ones carry information, but I only have to concern myself with the the ones on the ends which are positive and negative.
First of all I'm soldering the micro usb to some wire to connect to the lights, and they are so small and difficult to see! Took a little while to get that right. But this is what it looks like all connected.
I'm also putting on some shrink wrap to completely protect the connection and the wire - cause this is going to sit inside the concrete!
STEP 3: Lexan
OK, next up I'm cutting up some lexan into strips, and this is for the middle section of the lamp. I made them 1 1/2 inches or 3.8 cm high, and totally the lamp will measure 3 1/2 x 3 1/2 x 3 1/2 inch (90 x 90 x 90 mm). To frost the glass, I sanded the pieces with fine sandpaper, but you could also spray with frosted spray paint. Then I mixed up some epoxy and glued the sides together to form a square.
STEP 4: Molds
Now, let's move on to the concrete molds. I'm just using some scrap plywood here, so I've got some pieces cut up which I'm just drilling and screwing together. To protect the plywood from the moisture and make it a little easier to separate from the concrete I spray painted them with som glossy paint.
STEP 5: Concrete
Time to mix up some concrete! But first, remember this little micro usb wire? I'm putting some tape on the connection end to protect it.
Then I'm mixing up the concrete, and this is actually mortar mix which is smoother than traditional concrete and doesn't have the gravel and stones in it.
STEP 6: Assembling the Blocks
So I've got two molds, one for the top and one for the bottom. First putting down a layer of concrete. Then laying the usb wire down flat, with the tape covered usb opening against the plywood. Then I put on some more concrete on top to fix it in place, and cover up to the edge, but I made sure to have the wires point up straight in the middle.
Then repeat with the top mold, which is the same but without the wire.
Once dry, I unscrewed the molds carefully, and pried the bottom plywood apart, and I had my blocks.
STEP 7: Testing
Now I actually did this multiple times, experimenting first with different wetnesses, and I know dry concrete is supposed to be stronger, but I liked the wetter concrete more in terms of looks, a little smoother.
On my third attempt here, I also placed the lexan square in the wet concrete to create an indention, and that made the plastic square fit better once dried without many gaps.
STEP 8: Sanding
Once I had the blocks, I sanded them - first I used a sander, and the dryer blocks needed more sanding. But then I moved to sanding by hand - and I also found that the blocks made with wetter concrete didn't need nearly as much sanding, they were pretty smooth already, apart from some sharp corners.
STEP 9: Connecting the LEDs
OK, now the next step here was to solder on the led strip to the wire coming up from the concrete. And just testing here to make sure everything works. Now to secure the lights in the middle of the block, I simply used hot glue and I kind of glued the strips on top of each other into this tower thing. And then just putting it all together.
STEP 10: Bottoms
To make sure the concrete bottom doesn't scratch a table surface I'm cutting out some rounds out of leather for feet and then just hot gluing those on as well.
STEP 11: Frosting
I also cut up some paper that I glued on the inside of the plastic square, and this is because I didn't actually want to see any of the individual lights, and the paper dimmed it even more so there was just this glow.
Once everything looked good, I epoxied the plastic square to the concrete pieces. I also put some shellac on the concrete to seal it.
And there it is. To turn the light on, you can either plug in a 5 volt power bank to make it portable and use anywhere, or you can plug in to any standard phone charger or your computer.
STEP 12: Conclusion - Watch the Video
For a much better perspective, make sure to watch the video to see all the steps in detail and the finished result.
84 Comments
Iggylu 6 years ago
I can't wait to make this!
Thanks for putting this up!
zonkerharris 6 years ago
I like the idea of using mortar-concrete, and you showed a good approach for protecting the connectors while adding the concrete. But I like to use color in my projects! This would lend itself well to Neopoxels and an ATtiny or small Arduino Pro Mini, etc. (One of my other projects has the code with comments, and could be easily adapted to just a few pixels. https://www.instructables.com/id/IKEA-Star-With-ATtiny-and-NeoPixels/ ) I also like the idea of the resin from Greg Rufato in the comments below.
WinsantS 6 years ago
Lovely... Can elevate the look of the room....
HenryC98 6 years ago
Great project. Thank you for the clear explanation
Ham It Up 7 years ago
Linn,
Another great idea using concrete! I like playing around with LEDs. I'll make a couple of these. I thought about making a cavity just large enough, in the top, concrete block where I could install a push button on/off switch. Install a small piece of tubing (plastic) during the molding process for the wiring to run through. I would glue the switch in place. (polyurethane glue!)
Gary
Cris DIY 7 years ago
fantastic!
cbrooksokc 7 years ago
Cute DIY. Thanks! Do you recall what thickness you used with the molds? I like to proportions of what you have and would like to match it. I see your dimensions for the Lexan is 1.5" tall, so I'm guessing 3/4" on the height of the concrete?
SirCooksalot 7 years ago
Her overall dimensions were 3.5" x 3.5" x 3.5", so with a 1.5" lexan strip you'd want both concrete 'slabs' to be 1". You can make the molds deeper for convenience sake, and just mark a line at 1". I'm making a bigger light, but I liked the ratio she used, it looks just right.... So I'm making a 6" cube, with a 2.5" lexan strip and 1.75" concrete slabs- 1.75" + 2.5" + 1.75" equals 6"- not precisely her ratio but VERY close.
Thanks for the tip. I'm making a slightly larger version as well. I'm also going to drop a Gemma in the middle to drive some Neopixels vs. straight white lighting.
MichaelC350 7 years ago
You can get led strips anywhere online. They're not likely to be locally available, at least not for me. I got a 15" strip with the USB cord already soldered on for about $5. So mine will have a standard USB wire coming out of the back, instead of a female micro-USB port, which should be fine. It will still plug into a phone charger so no issues there. If you google '5v LED strip' you will be on your way!
darbinorvar 7 years ago
All the products are listed in the description of the video:
https://www.youtube.com/watch?v=fwVxTm7bgqs
MichaelH653 7 years ago
not sure where your getting your information, I've watched 3 videos and have yet to find out where to acquire the LED lights and yet to find any material list.
BradJ37 7 years ago
Follow the youtube link and see the video description. You need to click on "Show More" to see the full description.
kbouchard1 7 years ago
You should be able to buy the light strips on Amazon or many other places, just google them. Most come in reels, depends on the price. You want to get the 5 volt types. RGB ones are more common, you just have to ground the RGB contacts and supply 5 V to the + contact. You cut them on the marked stripe, or cutting the solder lands in 1/2 to make them work properly. Duct tape will do if heat shrink tubing not available.
I might paint the concrete blocks sfter sanding them, masking off the wires and usb port. Also if you wanted to get complex you could use RGB light strips, and maybe mount 3 toggle switches into 1 side or even in the concrete and wire up to have color combinations, just a thought.
BlueEye.dk 7 years ago
I installed a arduino in it an a 24neopixel and a Bluetooth and when I get a message it slightly turns blue , ringing slightly red.
And there is a led chasing around , im thinking about putting in 2 24 neopixelrings.
When I'm done I'll put up a link.
Again thx for a great build, did not watch the video....
MauricioC23 7 years ago
Beautiful lamp!!!!! i need create one
MohammedZ37 7 years ago
Awesome work!
PURVAKD 7 years ago
