Concrete Mushrooms -- Yard Art
Intro: Concrete Mushrooms -- Yard Art
Like yard decor that's a little different? How about making yourself some concrete mushrooms? They're inexpensive and easy!
WARNINGS: As with any project, you will need to take proper precautions. Read the safety instructions on the products and follow them. Quikrete can be rough on your hands, so be sure to wear gloves when working with it. Wear a mask and work in a well-ventilated area to avoid breathing in concrete dust or PAM spray. Wash your hands thoroughly when you've finished working.
STEP 1: Gather Your Supplies
Supplies:
BOWLS for mushroom tops, sizes that appeal to you. Get a bowl with a nicely rounded (not flat) bottom interior. You can use any bowl that appeals to you esthetically. One of my bowls was plastic and the other was ceramic. I bought them at Goodwill very inexpensively. I wouldn't use a bowl that I plan to use for food later.
TUBE OR VASE for stem. (I used a Pasta Express tube..the kind sold on TV to quick-cook pasta, but you could use a vase or a paper tube. I cut the bottom off the Pasta Express so both ends were open).
PAM VEGETABLE SPRAY
1 bag QUICKRETE (1 made all 4 mushrooms with one 60 pound bag, but you will need less or more depending on the size of your mushrooms.) Available at home improvement stores like Lowes or Home Depot.
WATER (enough to mix into concrete).
MIXING SPOON strong enough to mix concrete
PLASTIC TUB to mix concrete in
PIECE OF PVC PIPE longer than your stem tube. (Available at home improvement stores like Lowes or Home Depot) Cut one end at an angle.
LANDSCAPE BLOCK ADHESIVE with CAULKING GUN -- (Available at home improvement stores like Lowes or Home Depot) comes in a tube like caulking.
ACRYLIC PAINTS -- The kind sold in 2 oz. bottles at craft stores like Hobby Lobby or Michael's. (example: Creamcoat or Americana)
PAINT BRUSH
SEALANT -- I used Daichcoat sealer, but you can use your choice of sealer. Consider whether you want a flat finish, medium gloss or high gloss to your finished mushroom.
STEP 2: Mixing Concrete
THIS PHOTO does not look accurate! It has not been mixed, therefore, looks like more water than you will need. To see what the concrete looks like when it is mixed properly, see step 4. You can add the water a bit at a time so you don't put in too much.
STEP 3: Spray Molds
STEP 4: Filling Your Molds
Put concrete into molds...I used my mixing spoon to spoon concrete into the molds. When molds are filled, tap the concrete to remove bubbles.
STEP 5: Once Molded...
Push the PVC pipe into the concrete-filled tubes. If you want your finished mushrooms to be tilted, put the PVC pipe in at a slight angle.
While wearing latex or rubber gloves, round the edges of the concrete in the bowls with your fingers to give your mushroom edge a smoother shape.
Let the concrete sit in the molds for 24 hours. DON'T rush this step as the concrete takes that long to properly set. If you take it out too soon, the concrete will be crumbly.
Times given are approximate. Weather, temperature and size of mushroom top will affect the drying time. If it's cold or damp or if your mushroom is really big, it will take longer to dry.
STEP 6: Remove the Molds
Leave the concrete sit for another 24 hours to dry thoroughly.
STEP 7: Painting Your Mushroom
I used Americana Acrylic paint
BASE COAT: Cocoa
SHADOW: Burnt Sienna
THIRD COLOR: Celery Green
Don't stress over the paint job...you're just looking to add a little dimension.
STEP 8: Attaching Stem to Mushroom
STEP 9: Attaching Top to Stem
STEP 10: Completing the Mushroom
Remember that concrete can be heavy! Lift the mushroom from the stem, not the top and have a solid grip on the whole mushroom before lifting it so nothing falls!
26 Comments
AC10 7 years ago
Great tutorial! but concrete needs to cure for a longer period of time and, unless you are soaking it in water for a few days, use a curing agent. If you do not cure correctly your art will crack and split.
lryder1 10 years ago
I use WD 40 for easy release. Works great and makes clean up super fast!
mikesnyd 12 years ago
framistan 10 years ago
mikesnyd 10 years ago
silverlace 12 years ago
precious11 12 years ago
zakamooza 13 years ago
suezq 14 years ago
THYMETOCHAT 14 years ago
The tubes for the mushroom bases I use are hard plastic, and they're about 3 inches across. I use PVC pipe (like for plumbing) down the center of the plastic tube (mushroom base). After you've filled the tube with Quickrete, you push the PVC pipe into the concrete. You can either push it straight up and down or you can tilt it at a slight angle. I say slight angle because if you put it at a steep angle, your mushroom will look like it's falling over.
You can also create a bit of an angle by pushing the PVC into the ground at a slight angle when your moshrooms are completed and you are placing them in your garden.
A bit of advice on the stepping stones...they need to be about 1-1/2 to 2 inches thick or they'll break when you step on them. Also, for stepping stones, you want fairly straight up and down sides so the thickness is the same clear to the edge. I have used cake pans from Goodwill for stepping stone molds. BE SURE to spray them with PAM before putting the concrete in. I didn't use PAM when I trued to use this cute dimensional lamb cake pan to make a little lamb for my memory garden. I never did get the concrete lamb out of the pan, it was TOTALLY stuck! Have fun!
suezq 14 years ago
fretted 14 years ago
But be careful when you paint them don't paint the inside of the bowl unless it's a non toxic paint to birds .....
I made sure it was thick enough so it would hold up. They sell a liquid concrete bonding agent at Lowe's that I might mix in with the concrete if I were doing another bird bath. The bonding agent (about $6 for a quart) does strengthen the concrete.
I pushed some colorful marbles into the wet concrete on the inside of the bowl to give it some sparkle. Then, I let it set for several days to dry and cure before pulling it out of the soil and mounting it on a tree stump.
I just used a hose to wash the dirt off the outside of the bird bath.
yodaandmoody 14 years ago
I would probably embed some chicken wire into the concrete to help reinforce the table top.
I see two problems, however. First, of course, is that it would be extremely heavy. Second, the mushroom top is rounded (like a dome) not flat, so you couldn't really set anything on the table without it falling off. BUT, if you do make a mushroom table and stools, I would enjoy seeing photos! Have fun.
BadVanGoh 14 years ago
starshipminivan 14 years ago
liggy 14 years ago
chaosrob 14 years ago
rimar2000 14 years ago
