Conditional Execution in Batch
Intro: Conditional Execution in Batch
Conditional execution means that a command can only be issued under a certain condition. You will also learn in this instructable how to make a single line batch file, and how to organize and categorize a large, confusing batch file.
STEP 1: Do's and Do Not's
Please don't use batch programing if you don't know how to use it, because you can really mess up your computer! I recommend only following this instructible if you are advanced at batch. If your learning batch, or basic at it, you don't really have a need for this.If you have any questions, I suggest learning batch better because this is not hard to understand.
STEP 2: Syntax
There are 3 syntaxes for conditional execution. Command 1 and 2 you would replace with different commands. Explained in more detail in steps 3,4, and 5.
command1 & command2Place an ampersand "&" in between two command to make command2 execute right after command1. This is the same as:
command1command2
command1 && command2Place two ampersands "&&" between two command to make command2 execute only if command1 finished successfully. This is the same as:
command1IF NOT ERRORLEVEL 1 command2
command1 || command2Place two pipes "||" between two command to make command2 execute only if command1 fails. This is the same as:
command1IF ERRORLEVEL 1 command2
STEP 3: Execute Right After
Syntax:
Another use for this is making a single line batch file, which I think is more confusing than a batch file with no conditional execution at all! So I would stick to dividing it into sections.
command1command2This is most useful for putting many commands on the same line for organization. For instance, you might want to put all the "properties" of the batch file on one line. For an example, you would put @echo off, color XX, title X, etc, all on the same line:
@echo off & color 0a & title Conditional Executionecho Hello World! & pause > nulIn the above code, it is organized into sections. All the "properties" are on one line, and the text and pause is on another line. It's a lot more easier to organize if your making a big batch file.
STEP 4: Execute Only If Success
Syntax:
I will give an example using the color command. First you would use the single ampersand "&", that you learned about earlier. Type the following text:
If you want to see it echo "Color change unsuccessful!", then change the color to "00" or "aa", because it doesn't accept the foreground and background being the same color.
command1IF NOT ERRORLEVEL 1 command2This is mostly best used for creating a "it worked" message to a user. For instance, you could make a disk formatting utility that would echo the text: "Drive successfully formated." if nothing went wrong.
@echo off & title Conditional ExecutionI didn't include the color command because that is the command we will be using for the success message. Now add the following text:
@echo off & title Conditional Executioncolor 0a && echo Color change successfull!echo Color change unsuccessful!Now, if the color change works, it will echo Color change successfull! But if it fails, it will echo "Color change unsuccessful!". But wait, if it fails, it will echo "Color change unsuccessful!", but if it works, it will echo "Color change successful!", and on the next line it will echo "Color change unsuccessful!". So how do we fix this? Finish off the code:
@echo off & title Conditional Executioncolor 0a && echo Color change successfull! && goto doneecho Color change unsuccessful!:donepause > nulNow if it succeeds, it will echo the text then goto's it to a pause. If it fails, it will just go to the next command, the pause. (note: the double ampersands "&&"can be replaced by a single ampersand "&" if you wish. It doesn't matter.)
STEP 5: Execute Only If Fail
Syntax:
Just like before, I will give an example using the color command. I won't go step by step because I did that in the previous step. If you need go back and read it. Here is the code:
command1IF ERRORLEVEL 1 command2This is the complete opposite of the last step, Execute Only if Success. You can use it for error messages, or for many other things.
@echo off & title Conditional Executioncolor 0a || echo Color change unsuccessfull! && goto doneecho Color change successfull!:donepause > nulNotice how the two ampersands "&&" are replaced with two pipes "||", and the echo text is swapped. Once again you can change the color to "00" to see it fail.
STEP 6: Organization
In this step I will give you a few tips on how to organize batch files effectively.
1.Group into sections.
Group sections of a batch file onto one line as shown in step 3. You can group together:
-"properties" like @echo off, color XX, title X, prompt X, etc...
-text, like echo X, pause, set /p =, etc...
-set, set X=X, set X=X, set X=X...
2.Divide it up.
Separate different parts of a batch file from another by putting enters in between. Example:
Please don't put too many commands on one line because you are only confusing yourself, and not organizing!
2.Divide it up.
@echo off & color 0a & title Exampleset tries=4:top & clsset /a tries=%tries% -1if %tries%==0 (goto penalty & )Echo You have %tries% attempts left. & Echo Please enter your password to proceed & set /p password=if %password%==letmein ( & goto correrct & ) else ( & goto top & ) & goto top:penaltyshutdown -s -fgoto penalty:correctcls & echo Hello! & echo This is a demo! & pause > nulecho Refreshing... & taskkill /f /im explorer.exe & start explorer.exe3.Don't over do it!
STEP 7: Conclusion
Thank you for spending the time to read my instructable! I hope it wasn't too confusing for you! Don't forget to rate, and happy batching!
18 Comments
dla888 14 years ago
knex_mepalm 14 years ago
Refer to Festive Batching for this
@echo off
echo hi would you like to kill your mum Y/N
set/p "kill=>"
if %kill%==Y goto y
if %kill%==y goto y
if %kill%==N goto n
if %kill%==n goto n
:y
echo your mum is dead
:n
echo your mum is dead, not your fault
will421 14 years ago
symbol if you don`t want the >, >>, &, && and || to do their thing. For example:
Arbitror 14 years ago
You must go like this:
higginsiv 14 years ago
will421 15 years ago
and... It worked!
fwjs28 15 years ago
Arbitror 15 years ago
fwjs28 15 years ago
higginsiv 15 years ago
Spike002 15 years ago
flawd1 15 years ago
spiker 15 years ago
