Connect Your Raspberry Pi and Arduino Uno!
Intro: Connect Your Raspberry Pi and Arduino Uno!
Both the Raspberry Pi and Arduino Uno are very powerful devices, good at different things. The Arduino boards are awesome at reading inputs and outputs from various different things. The Raspberry Pi is basically a mini, open-source Linux computer. If you put these two together, your options are limitless.
That's what this tutorial is about. Putting these two together, over USB and Serial Communication! Let's get started.
STEP 1: Materials List
In order to get a good understanding of this project, you will need the following materials:
- Raspberry Pi B+
- Arduino Uno
- Breadboard
- Jumper Cables (4)
- LEDs (3)
- 220 OHM resistors (3)
You can use the same colored LEDs if you wish, but different colors are easier to visualize.
STEP 2: The Circuit
The circuit itself is very simple. Follow the diagram and you'll be good to go.
STEP 3: Arduino Code
In order to install run Arduino on your Raspberry, you will need to type the following into the LXTerminal. You could also try to download the Linux ARM file, but I couldn't get it to open on the Raspberry pi.
sudo apt-get update && sudo apt-get install arduino
note: you must have an internet connection
(source: http://playground.arduino.cc/Linux/Raspbian )
Now that you have Arduino on the Raspberry Pi, copy and paste this code into your sketch:
char receivedChar;
boolean newData = false;void setup() {
Serial.begin(9600);
pinMode(3, OUTPUT); pinMode(5, OUTPUT); pinMode(6, OUTPUT); }
void loop() {
recvInfo(); lightLED(); }
void recvInfo() {
if (Serial.available() > 0) {
receivedChar = Serial.read(); newData = true; } }
void lightLED() {
int led = (receivedChar - '0');
while(newData == true) {
digitalWrite(led, HIGH); delay(2000); digitalWrite(led, LOW);
newData = false; } }
Plug your Arduino into the Raspberry Pi via USB and upload the code!
STEP 4: The Raspberry Code
Now, it's time to make everything fall into place. Enter the following code to set up serial communication between the Arduino and Raspberry. Go to the Desktop and open the IDLE application, and type the code in there.
>>> import serial >>> ser = serial.Serial('/dev/ttyACM0', 9600)
Once that code is entered, it is time for us to begin communication!
STEP 5: Communication!
As you know, the circuit includes three LEDs. The red LED is connected to pin 3, the green connected to 5, and the yellow connected to 6. You can use different colors if you like, but those are what I chose. Type these commands into the IDLE program.
Turn red LED on:
>>> ser.write('3')
Turn green LED on:
>>> ser.write('5')
Turn yellow LED on:
>>> ser.write('6')
When a command is entered, the LED told to turn on will light for 2 seconds, and turn back off! Now that you know how to do this, expand this idea into other things like servos, LCD screens, or whatever you can think of that communicates with Arduino!
STEP 6: Troubleshooting and Useful Links!
Raspberry Pi doesn't recognize the Serial port '/dev/ttyACM0' ?
The serial port could have a different name! To check....
1. Go to LXTerminal.
2. Unplug your Arduino.
3. Type in
ls /dev/tty*
4. Plug in Arduino.
5. Repeat step 3.
6. Check for a new directory file between the two times. The one that only shows up the second time is what you should use!
LEDs don't light when they should?
Check your wiring. Are your LEDs facing the right direction? Are your LEDs connected to the right pins? Always double check!
Serial Communication with Arduino - http://forum.arduino.cc/index.php?topic=396450
Other Projects - http://www.seeedstudio.com/recipe/166-basic-pi-lt-gt-arduino-communication-over-usb.html
27 Comments
TimB70 1 year ago
Currently the Arduino doesn't seem to either recognize a signal from the PI or the set up is incorrect.
Yes I can buy systems that do this already but I own the PI and quite a few UNO's so just trying to get it working.
Connected to the computer it will run, I want to have it stand alone so I don't need my laptop connected to the circuit.
yumadome 4 years ago
JamieB226 4 years ago
r.degenkamp 2 years ago
Jjss90up 5 years ago
beautiful tuturial
but I have a question
how can i read the status of the arduino inputs on rastberry?
and why is it that when I dial an output with the number above 9 it does not turn on?
thank you
The same way you could turn leds on and of or telll the arduino to read an input and send the result over the serial output.
Converting everything to ascii characters on both sides would be the easyest way to stop you from getting unpredictable results.
lgotje 4 years ago
theguymasamato 4 years ago
Very helpful.
eduardonobresilva 4 years ago
amtanaam22 5 years ago
MUKESHBADIGINENI 5 years ago
shivakumar1995 6 years ago
the command " ser.write('3') " is not working. I checked the leds they are fine and their polarity is also correct. what might be the problem here?
ryki2658 5 years ago
should look like this:
ser.write(str.encode('3'))
LouieL21 6 years ago
Use Python 2 (IDLE). Run the module file then enter 'ser.write('3')' in the shell.
MalluS1 5 years ago
sir greatwork that u have done same i too did ..can u turn on the LED through your voice by using input as Microphone.LED should be turned only after recogning your can we try this.can u guide me can u tell me how to send the commands from raspberrypi to arduion
MortenB14 5 years ago
pi@raspberrypi:~ $ sudo apt-get install arduino
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package arduino
is there a diffrent command i can type in to install the arduino ide on the raspberry pi?
KalpanJ 5 years ago
+1! Great, simple tutorial
andremvilar 6 years ago
Thanks for share this project, it was so easy and also elegant to make this connection I am very happy with the results, I was looking for such connections but only find difficult and not cristal clear projects. This one realy works. Thanks.
genesisquilala 6 years ago
Dude. Please help me . We have a thesis. How can i connect rasbery pi to arduino? is there any application i can used? Heeelp me i need to run arduino using rasbery pi please here is my fb. cexz.quilala and my email @cexz.quilala. Please i will pay if u want please asap. jut pm me
twicejiggled 6 years ago
You need to do this for a thesis? This is easy man, and there are tons of guides online of multiple ways to do it! Spend more then 10 minutes googling and i'm sure you'll find a a few step by step or video guides.
