Introduction: Connect a Light to the Weather Forecast
Use the weather to change the color of your lamp, to create your personnal ambiance !
Step 1: Get a Z-wave Key and the Bulb:
https://www.amazon.fr/Aeotec-Z-Stick-Manette-Adaptateur-ZW090-C/dp/B00YETCNOE?ie=UTF8&creative=22722&creativeASIN=B00YETCNOE&hvdev=c&hvnetw=g&hvqmt=&linkCo de=df0&ref_=asc_df_B00YETCNOE34044884&tag=googshopfr-21
The bulb:
https://www.amazon.fr/Aeotec-LED-RGBW-lampoule-ZW098-
C55/dp/B0117ZX936/ref=pd_sim_60_11? ie=UTF8&dpID=31FhkNgq7DL&dpSrc=sims&preST=_AC_UL160_SR115%2C160_&refRID=T3T9 BWX3A8KWRP371MCW
TimeSquAir :
https://www.amazon.fr/Digital-Airways-TimeSquAir-connect%C3%A9-
%C3%A9ducatif/dp/B014D0RBWC
Step 2: Download Z-Wave Node on TimeSquAir
Go on the menu → import → node then type «ttb-zwave», wait for the install then reboot.
Step 3: Connect Your Key and Your Bulb to TimeSquAir
I let you refer at those tutorials, I can't explain better:
Connect your key:
http://thethingbox.io/docs/ZwaveUI.html
Connect your Bulb:
http://thethingbox.io/docs/ZWaveAeotecBulb.html
Step 4: Create the Flow
In the workspace «Z-wave» copie the node «Aeotec, LED Bulb» in a new workspace.
Then add the node «zwave» in the Automation section and activate the workspace. You can now interact with the Bulb.
Step 5: Get the Weather
Add the node «inject» and set it like on the first pitcure, you can set the interval as you want of course.
After that, link the nodes «meteo», «function», «switch» and finally two «Color» like on the second picture.
Let the node «meteo» as it is.
Open the node «function» and write this code inside:
"msg.payload = msg.payload.split(":");
msg.payload = msg.payload[1].split("°");
msg.payload = msg.payload[0];
msg.payload= parseInt(msg.payload, 10);
return msg;"
This code will get just the number of the temperature. At the beginning the node «meteo» display something like: «Paris:13°C». So what I've seperate this sentence with the method split(), first I'll seperate {Paris} and {13°C} with the caractere «:». Then I seperate {13} and {C} with the caracter «°». Finally I convert the string we have into an integer with the method parseInt().
Step 6: Configure the Color of the Bulb
Now you must configure the switch ( example on the fisrt picture). Then link it to the nodes color and set it like you want. Activate the work space and it's done !
