Connecting AC Power to Arduino for Beginners!
Intro: Connecting AC Power to Arduino for Beginners!
Hi there!! I'm here here to help as I can.
We can give only 5V to the arduino board from the power pack or from any source.
But we can't work with items which need more power as we only give 5v to the arduino board.
Giving more power can cause damages to the board. So you must be in a problem with that.
And also when using arduino board, you can't work with items which are running from AC current.
Connecting some parts such as motors directly to the board is also harmful.
So we can make the arduino circuit and the connecting appliance as separate circuits.
STEP 1: Connect Through Transisitor and a Relay...
We can use a transistor to link between the two circuits without harming the arduino board.
Give the arduino pin to the base pin of the transistor.(connect a resistor to lower the base current.)
I used the transistor "D400". and a 1kilo ohm resistor.
Then you can connect any DC circuit to this transistor's emitter and collector.
Then you can control the circuit by the arduino board by adjusting the base current.
If you want to connect an AC circuit, you can use a relay.
I've used a 6V relay\ 220V AC.
Connect circuit as in the above image.
Add a diode to avoid the damage that can happen to the arduino by the spark stored in the relay after shutting the power supply.
then you can connect the needed appliance or the circuit to the place I've labeled in the above image.
(be careful when dealing with AC current. Please do this with an elder)
2 Comments
tomatoskins 7 years ago
Great idea! I love finding little tricks like this!
Geethaka 7 years ago
Thank you sir! This is my first instructable.
I'm a beginner.:)
