Connecting Arduino to MySQl Database W/ USB Using MysqlIO
Intro: Connecting Arduino to MySQl Database W/ USB Using MysqlIO
I always thought about controlling arduino from another device over Wi-Fi or internet, but I didn’t want sacrifice any pin for communication. I already made a project to control my PC with arduino using IR remote (You can find the link here).
I upgraded the project to next level to communicate to MySQL database. Arduino sends data via Serial port to mysqlio in specific format i.e. “query=SELECT * FROM arduino”. Mysqlio detects these specific keywords and extracts the mysql command from the received string. Then it sends the same extracted mysql command to perform query.
I already found an instructable to communicate to mysql database for Linux and Mac systems in python. Windows doesn’t allow control serial ports from that application, moreover the mysql library that I designed is completely similar to real MySQL syntax, it seems like you doing MySQL in arduino itself.
I submitted this project for contest, so please vote if you like it.
STEP 1: Materials Required
- Any Arduino
- USB cable A to B
STEP 2: Development Tools Required
- Arduino IDE (Link to download IDE)
- Wamp Server or another MySQL service (Note: You can also use any free MySQL server from internet, it will give your project wireless capabilities)
- And of course, MysqlIO
STEP 3: Setting Up the Database for Arduino
Run Wamp Server and open your internet browser, type ‘localhost’ in the address bar. You’ll see something as this image.
Click on phpmyadmin and create a new database ‘arduino’.
Now, create a table, name it as ‘sensors’ with 3 fields.
Use this as reference:
‘id’ as INT with auto increment.
‘name’ as VARCHAR of size 100.
‘value’ as INT.
Save the table, and now we are ready to code arduino.
STEP 4: Coding the Arduino
Extract the downloaded mysql.zip files in arduino’s libraries folder.
Restart the arduino to load the mysql library. Then go to: File>Example>mysql>ConnectToMysql
Change the user and password according to your mysql server configuration.
Upload the code to arduino.
STEP 5: Talking to MySQL Database With Arduino
Download and install the MysqlIO app. Make sure Wamp Server is running else it will give an error.
Select the com port to which arduino is connected and the baud rate.
Mysqlio will receive data from the arduino and decode the received data into useable mysql commands.
As you can see, Connected to localhost and Disconnected which indicates that arduino has successfully connected to mysql database arduino.
Try other examples like, InsertRecord, DeleteRecord or any other code of your own.
You can also alter the parameters with variables to store sensor’s data over mysql database.
STEP 6: Conclusion
Creating a website or another app to read these values in mysql database and performs events according to the values will give unimaginable powers to your project.
If you use an online mysql server instead of ‘localhost’(i.e., host=”mysql.yourdomain.com”) your project gains the power of internet via USB cable using no Wi-Fi or Ethernet shields, all you need is to connect your computer to internet.
I’m not aware of any other app or library which can communicate to MySQL database in much simpler syntax. I already created a website with complete documentation and examples of Mysqlio application (here), it is completely open-source. You can download the Mysqlio source code and improve the app, it is written in VB .NET, you are welcome to any suggestions.
You can also download the Source code of MysqlIO, MysqlIO app or Arduino's library from my website too, there you will find references of other functions.
I already created another project to control the arduino from a php website on Wamp Server. Using MysqlIO app, I will post that instructable soon.
34 Comments
Ir Gloire 1 year ago
paribesh_c 1 year ago
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
C:\Users\parib\AppData\Local\Temp\arduino_modified_sketch_127409\ConnectToMysql.ino: In function 'void setup()':
C:\Users\parib\AppData\Local\Temp\arduino_modified_sketch_127409\ConnectToMysql.ino:30:9: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
host = "127.0.0.1";
C:\Users\parib\AppData\Local\Temp\arduino_modified_sketch_127409\ConnectToMysql.ino:31:9: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
user = "root";
C:\Users\parib\AppData\Local\Temp\arduino_modified_sketch_127409\ConnectToMysql.ino:32:9: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
pass = "Admin@456";
C:\Users\parib\AppData\Local\Temp\arduino_modified_sketch_127409\ConnectToMysql.ino:33:7: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
db = "medsupport";
C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp: In function 'int mysql_connect(char*, char*, char*, char*)':
C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp:31:5: error: redefinition of 'int mysql_connect(char*, char*, char*, char*)'
int mysql_connect(char *host, char *user, char *pass, char *db){
C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp:10:5: note: 'int mysql_connect(char*, char*, char*, char*)' previously defined here
C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp: In function 'String mysql_result_query(String, String)':
C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp:67:10: error: conversion from 'int' to 'String' is ambiguous
return 0;
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:232:0,
from C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp:7:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/WString.h:61:2: note: candidate: String::String(const __FlashStringHelper*)
String(const __FlashStringHelper *str);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/WString.h:59:2: note: candidate: String::String(const char*)
String(const char *cstr = "");
C:\Users\parib\OneDrive\Documents\Arduino\libraries\mysql\mysql.cpp:71:10: error: conversion from 'int' to 'String' is ambiguous
return 0;
exit status 1
Error compiling for board Arduino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
please help.
NathM1 5 years ago
D:\Installed\Arduino\libraries\mysql\mysql.cpp: In function 'int mysql_connect(char*, char*, char*, char*)':
D:\Installed\Arduino\libraries\mysql\mysql.cpp:31:5: error: redefinition of 'int mysql_connect(char*, char*, char*, char*)'
D:\Installed\Arduino\libraries\mysql\mysql.cpp:10:5: note: 'int mysql_connect(char*, char*, char*, char*)' previously defined here
exit status 1
Error compiling for board Arduino/Genuino Uno.
please help me i can't connect to wamp server
sonalmane517 2 years ago
muskanp1 5 years ago
MIAN SAQLAIN 3 years ago
please contact with me. It wll be a great favor.Thnaks
Email: MIANSAQLAIN237@GMAIL.COM
sharisankar76 4 years ago
hajouraa 4 years ago
Alegzandriuno 4 years ago
ronak_jadav 5 years ago
JahnaviR2 6 years ago
I have a doubt regarding the RetrieveRecord in that library.What's the need of using digital pin 12 there.
ANy one please explain this to me.
if(result == "False")
digitalWrite(12, LOW);
else
digitalWrite(12, HIGH);
ThankYou.
RishithaS 5 years ago
I have this problem. Its a problem with the library.
C:\Users\user\Documents\Arduino\libraries\mysql\mysql.cpp: In function 'int mysql_connect(char*, char*, char*, char*)':
C:\Users\user\Documents\Arduino\libraries\mysql\mysql.cpp:31:5: error: redefinition of 'int mysql_connect(char*, char*, char*, char*)'
C:\Users\user\Documents\Arduino\libraries\mysql\mysql.cpp:10:5: note: 'int mysql_connect(char*, char*, char*, char*)' previously defined here
C:\Users\user\Documents\Arduino\libraries\mysql\mysql.cpp: In function 'String mysql_result_query(String, String)':
C:\Users\user\Documents\Arduino\libraries\mysql\mysql.cpp:67:10: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
C:\Users\user\Documents\Arduino\libraries\mysql\mysql.cpp:71:10: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
keerti_vardhan 6 years ago
After completing all the steps when I am trying compile the code in Arduino is always throwing this error:
mysql.cpp:74:10: error: converting to 'String' from intiailizer list would use explicit constructor 'String::String(int, unsigned char)'
return 0;
We tried various ways to resolve this but still it is not working.
Please help me with this.
SajiM5 6 years ago
Unable to install due to error when installing Mysqlio application.
"The application requires that assembly MySql.Data version 6.9.4.0 in the GAC first
What to do>
Just search in net for MySql.Data 6.9.4.0 version and download that.Then
again run the setup file.The error will not persist.Don;t download any
higher versions as they won't work.
And i just wanted to know whether all these code(connecting to database,retrieving records) worked for you.If so please let me know in the comment.Thank You.
Just search in net for MySql.Data 6.9.4.0 version and download that.Then again run the setup file.The error will not persist.Don;t download any higher versions as they won't work.
AhmedJ17 8 years ago
Hi am7,
I trying to use you your project in real life,
but I have this errors just like djsrini's ...
pleas update If you figure how to fix this.
thank you.
C:\Program Files (x86)\Arduino\libraries\mysql\mysql.cpp: In function 'String mysql_result_query(String, String)':
C:\Program Files (x86)\Arduino\libraries\mysql\mysql.cpp:67:10: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
return 0;
C:\Program Files (x86)\Arduino\libraries\mysql\mysql.cpp:71:10: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
return 0;
exit status 1
Error compiling.
