Constructing Geodesic Spheres on Google SketchUp
Intro: Constructing Geodesic Spheres on Google SketchUp
Here is an extremely simple tutorial on how to construct icosahedral geodesic spheres using the 3D CAD software SketchUp. It's so easy to do even a 1 year old could accomplish this.
The very first thing you need to do is to have SketchUp installed. You can download it for free (SketchUp Make 2017) at: https://help.sketchup.com/en/downloading-older-versions
Once installed, start the software
Set Conditions:
- Go to Edit > Edge Style > Disable Profiles
- Go to Window > Model Info > Units
- Set Format to Decimal > Meters
- Enable length snapping at 0.01m
- Enable display units format
- Enable angle snapping at 15.0 degrees
- Make all precision at 0.00m
Download the entire file for this tutorial (The SketchUp file)
STEP 1: Icosahedron - 1V Geodesic Sphere
An icosahedron is basically a 20 sided 3D shape made up of equilateral triangles. This is the standard format for most geodesic domes as it provides a minimum degree of difference in the surface area for each triangle face and the length of the edges (also known as struts).
It can also be called a 1V geodesic sphere. V means the number of triangle subdivisions on each side of the icosahedron.
STEP 2: 2V Geodesic Sphere
10 Comments
gmagyar6 3 years ago
frobiquet 5 years ago
Your download links do not work...
milaNova 10 years ago
So, Im stuck on step 1, photo 10,11 ... I cant get the second face as you are showing here. My faces look aligned to the red line :(
eerambach 10 years ago
rickharris 13 years ago
Imperar 13 years ago
