Introduction: Continuity Tester (Using Android Phone)
Continuity tester using android phone
Requirements:
1.Android Phone
2. 3.5mm jack or old headphone with mic
3. wire (multimeter probes is better)
4.Application
Step 1: Cut the Headphone
Step 2: Find the MIC and GND Wires
Step 3: Connect 3K Resistor Parallel to the MIC and GND
Connect 3K resistor parallel to the MIC and GND and connect the probes wire and solder it.
Step 4: Finally Insulate the Wires
Step 5: Install Application to the Phone
https://play.google.com/store/apps/details?id=com.topstarcreations.continuitytester
Step 6: Testing.
https://www.youtube.com/watch?v=djYh4hbMTLo
18 Comments
7 years ago
What fusing on the leads should I use to protect the phone against inadvertently placing across mains voltage?
Reply 7 years ago
if you don't know for 100% whether or not what you're working on is hot or not, than you shouldn't be working on it bro.
Reply 7 years ago
Don't check the charged components. no fusing.
7 years ago
Cool project. I really want to do but I can't do it now, because my phone had died. :/
Reply 7 years ago
you probably tested a condutor with voltage
7 years ago
Not a bad idea but as a technician in my past trade and current hobby, I will always relay on my trusted Fluke meters. Perhaps Fluke will come out with one (unless they one already)
Reply 7 years ago
They do, although it is a Bluetooth interface for the 287/289 series multimeter. The actual measurement is done by the multimeter and it is sent to the phone via the accessory. Just for the sake of it, I own a 289 and I just love it, after a 179 and 115 series. If not the best portable meters surely in the top three.
7 years ago
I love this instructable. I can't wait for full multimeter modules to be available for smartphones.
Reply 7 years ago
something like this ?
I have multimeters in just about every tool box, and car (at least 6 or 7, spread about), but my smartphone is almost always on my hip. Between datalogging, and reduction in size, I am right there with you, in the "can't wait" group.
Reply 7 years ago
hooray!
Reply 7 years ago
thank you sir.
7 years ago
Great idea! Having a continuity tester in your phone is much better than having to carrying around a multimeter all the time.
Reply 7 years ago
thank you sir.
7 years ago
what watt or volts are the 3k ohm resistor?
Reply 7 years ago
across the resistance below 0.5V
7 years ago
i like this and need one for my ground to antenna checking continuity...excellent might try to make myself...
7 years ago
Love the idea. Simple and easy to use. Do add a warning to remove any power from the circuit you are testing and make sure all capacitors are discharged, as your costly phone is at stake.
Reply 7 years ago
Thanks.. yes you are right.
I will surely add a warning.
