Introduction: Remote Control 4 Relay With Arduino Via WIFI (touchOSC+Processing)
Hello, i'm not english speaking so please understand my mistakes.
Mine was just an idea, i was curious, i googled some hours but there were a problem: i didn't found a pre-made script :)
I started from a script found on a website, but it was made for one relay, so i remade it.
This instructable is made for 4 relays but you can add how many you want.
Step 1: Materials Needed
Things you need:
• Arduino (I used UNO)
• 4 Relay Module
• Processing, you can download it from HERE if you need the library too here it is
The library should stay in C:\Users\Your Name\Documents\Processing\libraries
• TouchOSC on Itunes
• TouchOSC Editor from Here
• Jumper wires
Step 2: Wire the Relays to the Arduino
Now you have to wire the Arduino and the relay module.
Pins:
Arduion VCC <-----> Relay module VCC
Arduino GND <-----> Relay module GND
Arduino pin 11 <-----> Relay IN1 Pin
Arduino pin 10 <-----> Relay IN2 Pin
Arduino pin 9 <-----> Relay IN3 Pin
Arduino pin 8 <-----> Relay IN4 Pin
Step 3: Program the Arduino
Download the script and transfer it to your Arduino
Step 4: Setup Processing
Run processing, download and open the script.
Edit the COM port if necessary.
Step 5: Setup TouchOSC
Now we need to setup touchOSC, you can find your host by typing ipconfig on cmd if you are under Windows
Step 6: Upload the TouchOSC Interface
Now with touchOSCeditor open the 4relaycontol.touchosc file and press the Sync button, once pressed on the phone app go to Layout and press Add
Step 7: Test
Run the script on Processing by pressing the "Play" button and connect with your phone.
Press the buttons, if everythig is working the relays will change their status.
14 Comments
7 years ago
Hello, I have made your project and everything seems to work great, but I can't get the lights to actually turn on or off by remote. The circles turn red correspondingly in processing and the red lights on the relay board are on so I believe I wired it correctly. I think it may have something to do with the com being used simultaneously? Any solutions or advice? thanks
Reply 7 years ago
Hello, so when you press the button on your remote the relay's led turns on but the relay remains open?
If that happens i hould check if vcc have 5V maybe the voltage is to low to trigger the relay.
You could also test the pins that activate the relays connecting a led to the pin and gnd.
You can also check if the relay works with a test script.
Reply 7 years ago
No, I cannot even turn the red relay lights on or off. They switch themselves on or off depending on if I just started the processing script or the arduino one. It seems as if they refuse to share the same port. I can change the four black circles to red via my iphone though.
Reply 7 years ago
I made this script 2 years ago and i don't remember to much , today i will try it again maybe i can find your problem.
Reply 6 years ago
I just tried and can't get the buttons to trigger the relays. I tested the relays in arduino window and they work. Something is not communicating between the phone oscillator and the processing program. Please check code to see if there is a missing connection.
Reply 7 years ago
you try the script?
Reply 7 years ago
Did you find anything?
Reply 7 years ago
ok thanks so much I've tried everything
Reply 7 years ago
any ideas?
7 years ago
Give it us android apk.
Reply 7 years ago
Hello, i can't do that.
You have to buy it from the store or search it by yourself.
8 years ago on Introduction
Nice thing to construct & download
9 years ago on Introduction
Nicely done. Thanks for sharing this!
Thank you :)
