Control Your Multicolor LED Using Smartphone!!
Intro: Control Your Multicolor LED Using Smartphone!!
Hello, everybody!! I am back this time to share with you an instructables I made during the weekend. I hope everybody is fine and Let's get to the first step shall we?
STEP 1: STEP 1: Items Needed
Hardware:
HC-06 Bluetooth Module
RGB/Multicolor LED
Arduino UNO
330ohm resistor x 3
male to male Jumper
Software:
Arduino IDE
MIT app inventor 2
STEP 2: STEP 2: Assemble the Circuit
Assemble the circuit as shown in the image. The circuit was designed by using Fritzing.The RGB/multicolor LED is common anode by the way.After the circuit assembly, we'll go the coding part. The coding part is divided into 2, Arduino IDE and MIT app inventor 2. Let's see the MIT appinventor 2 part first.
STEP 3: Step3: MIT App Inventor 2 Code Block
These are the design and the code blocks for the MIT app inventor 2. Make sure to follow the code blocks carefully as any mistake will cause more hassle. After the MIT code block, we are going to see the code for the Arduino section.
STEP 4: Step4: the Arduino Code
int redPin = 11;// red pin position
int greenPin = 10;// green pin position
int bluePin = 9;// blue pin position
int value = 0;//initial serial read value
void setup() {
Serial.begin(9600);//this is important. the baud rate between arduino bluetooth and smartphone
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT); //all the RGB pin were declared as output
void loop() {
while(Serial.available()){//if serial reading is available
delay(1000);//delay for a second, avoid overloading
value = Serial.read(); //value = serial value(led value)
Serial.print(value);//print the serial value
Serial.println();
if (value == 1)//the value which corresponds the MIT appinventor 2 byte sent. change accordingly to your own value here and MIT appinventor 2 code block
setColor(200, 100, 200); //turqoise
if(value == 2) {
setColor(0, 0, 255); // green
if(value == 3) {
setColor(255, 255, 0); // blue
void setColor(int red, int green, int blue) {
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);//set the colors for the RGB }
STEP 5: STEP 5:Test It!!
Download the apk file from the MIT appinventor and upload it into your smartphone. Then, upload the arduino code into your arduino with bluetooth. Then, its testing time!!! The testing video of this experiment is at https://youtu.be/heoPw4e_4z8
3 Comments
KözveszélyesV 8 years ago
Hi,
Can you export the application source code?
Thanks in advance!
halim930112 8 years ago
the code is here:
https://www.dropbox.com/s/gm980goypm4js7j/RGBLED_CONTROL.apk?dl=0
theredbryophyte 8 years ago
Thanks for a simple explanation on one way if using the bluetooth module with a phone - I didn't expect it to be that simple!
