Controll a Stepper Motor With the DRV8825
67,192
51
6
Featured
Introduction: Controll a Stepper Motor With the DRV8825
In this simple tutorial, I'll show you how to use the DRV8825 to control a bipolar stepper motor and how to use the micro stepping feature.
Step 1: Component List
Parts you'll need:
- A bipolar stepper motor ( capable of +9V input )
- The DRV8825
- An Arduino
- 100µF electrolytic Capacitator
Tools you'll need:
- A breadboard
- Some Jumpwires
- A Power supply
- A multimeter
Step 2: The DRV 8825
The DRV8825 is a simple but very powerful board that can control one bipolar stepper motor at the time and allows micro stepping up to 1/32 of a step.
PIN Description:
- VMOT: Power supply for the motor ( from 8.2- 40V)
- GND: Ground for the motor
- B1 & B2: Pins for the first coil of the stepper motor.
- A1 & A2: Pins for the second coil of the stepper motor
- FAULT(inverted):
- GND: Ground of the board
- DIR: Direction of the motor has to be high for clockwise and low for a counterclockwise spin.
- STEP: when this pin is high the motor spins one step further.
- SLEEP (inverted): Puts the motor in a sleeping state when HIGH
- RESET (inverted): Restarts the board when HIGH
- M2, M1, M0: Pins for the micro stepping
- Enable (inverted): Disables the Board when HIGH
Step 3: Connenting the Parts Togehter
In this step, I'll describe to modes for this stepper motor. The first one is very simple and the second one is when you want to do more complicated stuff ( micro stepping).
MODE 1:
Connect the parts as shown in the picture. please ignore the SLEEP and the RESET pin. You can use any Digital pins on the Arduino. be sure to change them in your code too.
MODE 2:
- DIR - D8
- STEP - D9
- SLEEP - HIGH (Vdd)
- GND - Arduino GND
- GND - Motor power GND
- VMOT - Motor power (check driver-specific voltage range)
- A4988/DRV8825 micro step control
- MS1/MODE0 - D10
- MS2/MODE1 - D11
- MS3/MODE2 - D12
Please ignore the RESET and the SLEEP PIN.
Step 4: Code
Code for Mode 1: please use the blink.ino
For step 2 please use the example code from this Library:
https://github.com/laurb9/StepperDriver
Good Luck and Have Fun!
Project by Alex Ghiriti and Marcel Büche
6 Comments
Question 2 years ago on Step 4
I am afraid following this tutorial can simply damage all my components isn't? the step 3 shows sleep and reset are connected to each other. whereas step 2 tells to supply 5 volts. So contradictory statements in 1line - "Connect the parts as shown in the picture. please ignore the SLEEP and the RESET pin". Strange.
3 years ago
Not working.
3 years ago
Sleep and Reset cannot be ignored, they must be pulled HIGH otherwise the board will not work. Also, there is no need (and possible damage can occur) if you tie the power supply ground to the micro-controller ground. If you must do so, place a properly sized diode to prevent micro-controller damage.
4 years ago
Not working!!
I have no voltage at Vref.
This is with two panucatt Devices 8825 and a Ramps 8825.
Really getting depressed.
Two years ago I had the panucat devices workng.
Ralph
5 years ago
Nice design. What is the max current output of this driver circuit?
Reply 5 years ago
It operates from 8.2 V to 45 V and can deliver up to approximately 1.5 A per phase without a heat sink or forced air flow (rated for up to 2.2 A per coil with sufficient additional cooling).
