Controlling DC Converter Modules
Intro: Controlling DC Converter Modules
There are many types of DC-DC converter modules for sale at very reasonable prices. Many of them, like the ones pictured, include two potentiometers for adjusting the output voltage and a current limit.
This Instructable is about how to control the output voltage from an external device, which can be either a potentiometer or a PWM signal from a microcontroller such as Arduino.
There are some general principles which I will explain. Then, for each module, there are some specific requirements which I will cover for the two modules I have used, which are
a) a module based on the XL4016 IC with a current capacity of 8 Amps; and
b) a module coded SZBK07 with a current capacity of 20 Amps.
Acknowledgment
Thank you to zopinter who originally showed how to control an XL4016 module with PWM.
UPDATE:These modules, and ones like them, can be found on EBay and Aliexpress by searching for "DC converter 300W". I also found modules coded YD4020J which appear to be identical to the SZBK07 module.
STEP 1: How the Output Voltage Is Controlled by a Pot
The way it works is this:
The pot is a variable resistance and is connected between OUT+ and Feedback. There is another (fixed) resistor between Feedback and Ground.
"Feedback" is the negative input of an operational amplifier. The positive input of that operational amplifier is connected to a reference voltage, which varies from one design to another but is usually between 0.8 Volts and 1.25 Volts. The XL4016 and SZBK07 are both about 1.2 volts.
These components form a negative feedback control loop that maintains the Feedback pin at the reference voltage. If the voltage at OUT+ is too high, the output of the operational amplifer goes down and decreases the PWM duty cycle of the converter, which decreases the output voltage. The converse happens if the OUT+ voltage is too low. Winding the voltage control pot one way to reduce its resistance reduces the output voltage; winding it the other way to increase its resistance increases the output voltage.
It is essential to have this feedback control loop formed by the pot, a resistor to ground, and the operational amplifier.
However if the pot is wound up to a high value, additional current from another source can be fed into the Feedback pin, which has the effect of reducing the output voltage.
One way of providing that additional current is by putting an external pot between OUT+ and the Feedback pin. Using a suitable value pot will give a new (lower) maximum setting for the OUT+.
Another way of providing additional current is to connect a resistor and diode coming from a PWM pin of a microcontroller. The resistor is needed to avoid drawing excessive current from the PWM pin. The diode is needed to ensure that the current is always additional.
STEP 2: Controlling the Voltage of the XL4016 Module
The Feedback pin of the XL4016 module can be identified in the photo above. It is actually 2 pins of the pot (they are already joined together by the makers). I soldered an orange wire across both pins, which makes a solid connection.
The on-board pot on this module is 10K, and the resistance from Feedback to Ground is about 360 Ohms. When the pot is set to its maximum value, the OUT+ voltage should be 1.25*(10000+360)/360=36 volts, which lines up with the specification.
If you want to use an external pot between Feedback and OUT+, a value of 22K Ohms will give a maximum output voltage of about 24 Volts.
If you want to use 5 Volt PWM via resistor and diode, and if you set OUT+ to 15 Volts with no signal (ie 0 PWM duty cycle), the chart shows what minimum voltage you can achieve as a function of the connecting resistance. So for example if you use a 2200 Ohm resistor, you can control the output voltage of the XL4016 module between 8 Volts (with 100% duty cycle) and 15 Volts (with 0% duty cycle).
STEP 3: Controlling the Voltage of SZBK07 Module
The Feedback pin of the SZBK07 module can be identified in the photo above (the red wire). It is actually 2 pins of the pot, but the middle pin has a surface mount component (I think it is a capacitor) soldered to it, so I just used the top pin.
The on-board pot on this module is 100K, and I expect the resistance from Feedback to Ground is about 4,000 Ohms.
If you want to use an external pot between Feedback and OUT+, a value of 220K Ohms will give a maximum output voltage of about 21 Volts.
If you want to use 5 Volt PWM via resistor and diode, and if you set OUT+ to 15 Volts with no signal (ie 0 PWM duty cycle), the chart shows what minimum voltage you can achieve as a function of the connecting resistance. So for example if you use a 22,000 Ohm resistor, you can control the output voltage of the SZBK07 module between 7 Volts (with 100% duty cycle) and 15 Volts (with 0% duty cycle).
STEP 4: Technical Details of the XL4016 Module
The XL4016 module is based on the XL4016 integrated circuit. Here is the first general description paragraph from the data sheet.
"the XL4016 is a 180 kHz fixed frequency PWM buck (step-down) DC/DC converter, capable of driving a 8A load with high efficienc, low ripple and excellent line and load regulation. Requiring a minimum number of external components, the regulator is simple to use and include internal frequency compensation and a fixed-frequency oscillator."
The XL4016 comes in a 5-pin TO220 package. The block diagram for its functional blocks from the data sheet is reproduced above (right side picture).
The XL4016 is designed to be used as an asynchronous DC-DC converter with the addition of an external inductor and external power diode, both atttached to the SW pin. The XL4016 provides the high-side switch in the form of a P-channel MOSFET internal to the device. That MOSFET is made with a partition to sense the current through the device and provide over-current protection.
The XL4016 module uses the XL4016 IC as its main switching control element, and adds an inductor (22 turns of 2 strands of 0.7 mm magnet wire on a T94 toriod core), a power diode (VD3, a STPS2045CT Schottky).
The module incorporates a low-side current sense resistor of 10 milli ohms, and a dual op-amp (LM358) that senses the current. If the current reaches the limit set by the current control pot, the op-amp feeds current into the feedback pin of the XL4016 IC which has the effect of limiting the current to the set value.
STEP 5: Technical Details of the SZBK07 Module
Technical details of this module have been more difficult to obtain and the following information may not be reliable. However it is the best I can find. This information came from a YouTube video at
The module uses a 20-pin surface mount control IC which is probably LM25116. Originally I thought it could be type LTC1625 which has a similar function, but comes in a 16-pin package. The Description part of the LM25116 data sheet starts with the following: "The LM25116 is a synchronous buck controller intended for step-down regulator applications from a high voltage or widely varying input supply. ... The LM25116 drives external high-side and low-side NMOS power switches with adaptive dead-time control. ..."
The inductor is about 12 turns of 3 strands of 0.7 mm magnet wire on a T94 toriod core.
The power MOSFETs are type TK80E08K3, which are rated for 75 Volts and have Rds-on of 7.5 milli-ohms at 25C.
54 Comments
nickobat 6 weeks ago
Thanks farmerkeith, this helped me a lot with my project (a smart battery charger) where I want the Arduino to monitor and alter the output voltage from a SZBK07, for example from a constant current charge upto 14.4V, and then a constant voltage charge by reducing the current. To achieve this I obviously need the Arduino to monitor the output voltage and current separately.
So given this external monitoring, can I still not remove the voltage pot and just provide a 0-1.2V PWM signal as feedback?
Also, it seems to me (possibly incorrectly?) that if the voltage pot is wound down to it's minimum, an output voltage way higher that 1.2V (the SZBK07 is supposed to be able to output 36V) would be injected straight into feedback. Have I missed something, or do SZBK07 users need to be carefull with the voltage pot setting to avoid damage?
Finally, I found a SZBK07 schematic that is probably a useful addition to your instructable?
Thanks again.
DannyZeee 2 years ago
I wish to know your thoughts on using a DAC, rather than PWM to control the output voltage? It seems as though it should be a better solution for a solar MPPT?
farmerkeith 2 years ago
Keith
ironmike 2 years ago
DannyZeee 1 year ago
juan3211 1 year ago
juan3211 1 year ago
I have not tried this yet. (Too many demands on my time) Anyone see why it will or will not work?
That being said, using these values allows me to set the pot of my buck to output 12.8V with no external inputs, and ramp the output up to nearly 15V, by Increasing the PWM duty cycle.
I am using an ESP32 running @ 240MHz, driving the bias voltage to the buck @39kHz with 11 bits of resolution. Ripple of the bias voltage to the buck is not discernable on my scope.
juan3211 1 year ago
I have implemented a MPPT with a SZKB07 in tasmota firmware.
I have worked with an ESP8266. I have coded my own module to include in tasmota firmware. If I get managed to work with it I will publish my code to github for every body, of course.
I am measuring every 50ms the IN3221 data and adjust PWM output. (I think is good enought as "sun" doesnt change so fast.
I think I have a hardware problem, not software.
The problem is that with a 100w solar panel i can't get the MPP.
I see the voltage in the panel varies from 14.5v (for example) to 19 or 20v in the next "PWM" duty.
And the other way round.
I hardly can't see voltages around 16 or 17v. (almost NEVER)
In tasmota firmware, PWM is 4Khz, and 1024 values in PWM. (10 bits)
I have this hardware in pwm output pin: 6.8k with a 1uF capactitor (low filter) and then a 20k resistor to FB pin of the LM25116, to get from 12v to 16v
May be I have a problem with resistors? capacitor? frecuency of PWM?
juan3211 1 year ago
juan3211 1 year ago
juan3211 1 year ago
farmerkeith's solution is still great for old 200-250W 30V panels.
aaklug 2 years ago
