[EASY] Remote LED Control With UPNP on Raspberry Pi
Intro: [EASY] Remote LED Control With UPNP on Raspberry Pi
every time, i was tried IOT projects with port forwarding on my iptime.
but, that was not well. and i was find some easily way to port forwarding automatically.
the upnp(Universal Plug and Play) has a function for request port forwarding to router and i use it with node js.
I think this project will helping your IOT projects
STEP 1: Install Node Js and Project Soruce Code
type this commands in your raspberry pi terminal
sudo apt-get install nodejs # installing node js sudo apt-get install npm # installing npm (node pakage manager)
you can check node js install succesfully
node -v # version check
and we must be download project source code
github(rpi_onoff_upnp) you can also check the code in this link
cd /home/pi git clone https://github.com/keepworking/rpi_onoff_upnp
go to the project directroy and install projects
cd rpi_onoff_upnp npm install # wait for install finish npm install onoff # this package using for controling GPIO
try run this project, will print log like this picture
npm start
STEP 2: Circuits
connect LED with raspberry pi GPIO 26
STEP 3: Testing
you can connect from your smart phone or descktop to this external IPs
it will showing itnerface like this
STEP 4: Finish
You will notice that it is much easier to remotely control than port forwarding manually.
I have commented on the feather hub as a source code, so I would like to make it easy to use it. thank you!
2 Comments
DIY Hacks and How Tos 5 years ago
Interesting project. I am going to have to try this.
yevgenyHong 5 years ago
I hope this helps your project.
If it does not work, tell me. I'll help you as much as I can.
