Introduction: Convert 35V DC to 9V DC Using 7809 Voltage Regulator
Hii Friend,
Today I am going to make a circuit of voltage controller.By using this circuit we can convert upto 35V DC to Constant 9V DC.In this circuit we will use only 7809 Voltage regulator.
Let's get started,
Step 1: Take All Components As Shown Below
Components required -
(1.) Voltage regulator - 7809 x1
(2.) Capacitor - 63V 470uf x1 {Here I am using 25V 470uf capacitor because I will give 17V DC Input.}
(3.) Capacitor - 16/V25V/63V 100uf x1
(4.) Input Power Supply voltage in DC - Input voltage<35V {Input Voltage Should be less than 35V DC}
(5.) Connecting wires
(6.) Clippers
Step 2: 7809 Voltage Regulator Pins
This picture shows the pins of this voltage regulator.
Pin-1 is Input,
Pin-2 is GND (Ground) and
Pin-3 is Output.
Step 3: Connect 470uf Capacitor
Solder +ve pin of 470uf electrolytic capacitor to Input pin/Pin-1 of voltage regulator and
Solder -ve pin of capacitor to GND Pin of the Voltage regulator as you can see in the picture.
NOTE : Voltage of capacitor should be greater than Input voltage.So connect 63V 470uf capacitor to parallel of input power supply as i connected in the picture.But Here I can use 25V 470uf capacitor because I have to give 17V Input which is less than Capacitor's voltage.
Step 4: Connect 100uf Capacitor
Next solder +ve pin of 100uf electrolytic capacitor to Output pin of the voltage regulator and
Solder -ve pin of capacitor to GND Pin of the voltage regulator as you can see in the picture.
Step 5: Connect Clipper Wire for 9V Output Power Supply
Now we have to connect clip wires to get constant 9V DC Output from this circuit.
Solder +ve output wire to Output pin of voltage regulator and
Solder -ve output wire to GND Pin of the Voltage regulator as solder in the picture.
Step 6: Connect Input Power Supply Clip
Now our circuit is ready so connect Input power supply wire to this circuit.
Connect +ve clip of Input voltage to +ve pin of 470uf capacitor and
-ve clip to GND Pin of the voltage regulator.
NOTE : We can give Input Power supply voltage upto 35V DC to this circuit.
Step 7: Reading
Now as you can see in the above pictures.
Picture-1)- I Give 17.6V DC Input and we get 9V Constant Output from this circuit as you can see in the picture-2.
NOTE 1: If we will increase the input voltage then Output voltage will be same i.e. 9V DC.
Like this we can make a circuit for getting constant 9V Power supply using 7809 Voltage regulator.
NOTE 2 : Add heatsink if 7809 Voltage regulator get heated.
Thank you
