Convert Prezi Into PowerPoint
Intro: Convert Prezi Into PowerPoint
Imagine you created a very valuable presentation using
Prezi but it turns out that part of your target audience is using MS PowerPoint and can’t view your product?
While Prezi may be a perfect solution for text and visual presentations that you can zoom in and out of, PowerPoint is still the oldest and most popular program for presentation making. Prezi Designers PresentationGeeks believe that it’s easier to convert your Prezi into PowerPoint to indulge one part of your audience than to rob the other part of the impressive visual effects of a Prezi presentation.
While there isn’t a direct way to convert one into another, a few simple steps can help you reach your goal.
STEP 1: Step 1: Create a Prezi Presentation
Well, here is an obvious one. You probably had it done already.
STEP 2: Step 2: Convert Your Prezi Into PDF
Click share – download as PDF (or Export to PDF if you are using Prezi Next). Prezi will proceed converting the presentation into PDF format.
STEP 3: Step 3: Turn PDF to JPG
There are many different ways you can convert a PDF-file to JPG format.
There are several free online tools you can find online, such as PDF to Image and Free PDF Convert.
STEP 4: Step 4: Create a PowerPoint Presentation
Use PowerPoint to create a blank presentation template. Insert the JPGs you extracted from your Prezi into the template.
Voila!
