Convert STL to DXF Using Open Source Tools
Intro: Convert STL to DXF Using Open Source Tools
Background
I recently did an arduino workshop at Makers Asylum, I also took my DSO nano v3 to show how PWM works. Came back home and found the stand for the DSO was missing. Also the one that came with the DSO was not good. So I decided to make one. I thought of designing it my self from scratch, but before I did, I searched thingiverse for similar stands, luckily I found one(here), the design was robust and I just had to cut it out. I have a laser cutter,no 3d printer sadly. So had to convert the stl to dxf for my laser cutter.
I looked for some stuff online to convert it but it just didn't cut it.
Tools Used:
For those who want to go gungho, import the stl in blender, clean the file so that only the contours of the object remain, export it as DXF.
Before you begin make sure you have blender and Qcad installed and the stl file that needs to be converted.
STEP 1: Import File in Blender
Start blender, you be show a cube a camera and a light source, press 'a' to select all and 'x' to delete it.
- Go to File>Import>STL
- Open up your stl, use scroll wheel to zoom out.
- Press tab to go in edit mode, now all the vertices will be selected. Press 'a' to deselect,
- Press '1' on NUMPAD to go to front view
- Press 'z' for skeleton view
- press 'b' for border select, click and drag so that all the upper vertices are selected. DO NOT SELECT THE FULL MODEL(refer the images)
- press 'x' to delete, a menu will pop up, asking what to delete, select vertices. Make sure you are in Edit mode, else the whole STL will be deleted.
- Now you should have a flat shape.
now its ready to be exported.
- Go to File>User preferences>Addon>Import-Export> check mark Export autocad dxf format. close the dialog
- Dxf should now be visible in the export options
- Go to FIle>export>autocad(.dxf)
- Save window will open up with some options on the left.
- Select projection as "TOP"
- Export mesh as "Polylines"
That is it, now your dxf is ready.
STEP 2: Open in Qcad
Fire up Qcad and open the exported file.
In this example one small line was missing, so clean that up. now the tab size were 4mm thick so I had to reduce the size to 3mm, as I'm using 3mm acrylic for laser cutting.
13 Comments
fighterbee87 4 years ago
When I delete the vertices everything disappear, what am I doing wrong?
Thank you very much
hemalchevli 4 years ago
I was able to import the dxf into qcad, but it was not the correct shape, instead it was just a line, I tried to export from all of the different perspectives and I would get either nothing, a vertical line, or a horizontal line in Qcad
AndyLatimer 4 years ago
InformaciĆ³nI 5 years ago
Question I have 3D STL and I want to convert to 2D DXF...which I guess means a lot of "slices".
How can I do it?
Many thanks for your time!
LindseyOwn 7 years ago
Having trouble with this one... It's exporting fine, but once I get into Illustrator, there are still a gazillion internal lines that I have to delete before it's a cut-able outline. I get what you're trying to do with deleting all the other lines within Blender, but I haven't been able to delete that precisely, and I'm just trying to flatten a very very simple .stl... (One of these cuties: http://www.thingiverse.com/thing:752901/#files)
Still hammering on it... Thank you for the Blender tips!
hemalchevli 7 years ago
Hi, I tried one of the files it, I used qcad to delete the extra lines. I managed to clean the line quite easily.
jcar01 8 years ago
Can you please fix your instructable. when you select vertices and delete them the entire STL is deleted. Thanks
akienm 8 years ago
Missed a step. I've never used Blender before today. Apparently you have to be in edit mode rather than object mode to delete vertices. Took me some time to figure that out. :)
yvan den bossche 8 years ago
haha.
6.7.8. select vertices, delete them, you should now have... nothing whatsoever...
seamster 9 years ago
Nicely done. Thanks for sharing this!
hemalchevli 9 years ago
Just curious, Are you a bot?
Ha ha. Look at my profile, I am definitely NOT bot, although I feel like one sometimes!
Tutorials like this a great. I may not need it right now, but someday I might. This is the kind of stuff people go searching for online and are extremely grateful when they find it. It's excellent that you've taken the time to share this with the world.
