Convert a Water-resistant Sport Watch Into a Dive Watch
Intro: Convert a Water-resistant Sport Watch Into a Dive Watch
Problem: I spend long hours underwater at shallow depths and I need to keep track of the time.
Parameters: I don't need the fancy features of a $500+ saturation dive watch, however the cheap "water resistant to 50M" watches are not up to the task. I don't even need the features of the cheap watches either, I just need something that will display the time and not get destroyed by a few hundred hours at 20 feet.
Solution: Encapsulate a cheap sport watch in clear polyester resin.
STEP 1: Get Supplies
Step 1. Get supplies. Cheap water-resistant sport watch with large display, suitable mold, clear resin, hardener.
STEP 2: Prep Watches
Step 2. Prep watches, set time/mode, remove bands.
STEP 3: Add First Layer
Step 3. Add first layer, 1/2oz each. Mix resin and hardener according to instructions on package. Pour a thin "face layer" and wait 30 minutes for it to gel. Otherwise, the watch will sink to bottom and will not be encapsulated properly. Use stir stick to remove any bubbles from bottom of mold.
STEP 4: Add Watches and Second Layer
Step 4. Add Watches and second layer, 1oz each. Use stir stick and coat watch face with resin, remove all air bubbles. Pour a some resin on top of first layer, place watch in resin, move it around to dislodge any air bubbles. Pour in rest of resin layer. Watch should be completely covered. Let sit 30 minutes until this layer gels.
STEP 5: Add Straps and Third Layer
Step 5. Add straps and third layer, 1/2oz each. There needs to be a way to strap the watch to your person, you should have figured out something to use and have it ready. I used the straps off a sleeping bag, they come with locking clips and plenty of strap. Use stir stick to coat both sides of the strap, removing as much air as you can. Place strap on top of second layer. Pour the rest of the third layer over strap. Wait 4 or so hours.
STEP 6: Remove From Mold.
Step 6. Remove from mold. After the resin has mostly cured, 4 hours or more, it will shrink slightly and pull away from the mold. It should pop right out, perhaps with a gentle tug.
STEP 7: Inspect Awesomeness
Step 7. Inspect Awesomeness. Two totally encapsulated watches for a total of about $50 (Two watches: $17 each, 1/4 of the $30 resin+hardener, found straps), they should meet all my dive watch needs. If the any of the watch is exposed, simply mix some more resin, place in the mold, and put the watch in on top. This should form a new layer and bond to the previous layers.
25 Comments
SWV1787 13 years ago
safonatt 13 years ago
sjdaskldd 7 years ago
Solar pwered CASIO watches have gotten really cheap.they are now about 30 bucks for the cheapest.You may have just gotten an atomic solar g shock by now.
ahh you are in Alaska? I see why you have not obtained a proper dive watch.everything is expensive there .For an oil filled watch i have heard Hydroil is best.
VEy clever but I may have abetter idea.You could get a 100 meter water resistant CASIO on clearance sale or get a VOSTOK amphibia or Komandirskie.
An amphibia from Meranom.com should cost about 60 bucks plus shipping.They are tough as nails and look good.
Daveyboy1234 8 years ago
safonatt 8 years ago
And now that I'm one of the most successful Bering Sea gold miners and can easily afford your nice Rolex, I don't need one because I operate a remote operated underwater miner and rarely need to dive under those conditions.
VadimS 13 years ago
Another method (as previously stated) is to fill it with oil, just re- assemble it in a cup of oil to make shire there are no bubbles. Mineral oil is your best bet.
The most likely spot for them to leak is the buttons.
paleologos_the_greek 10 years ago
VadimS 10 years ago
rdillon 12 years ago
safonatt 12 years ago
Grazerquart 11 years ago
Mustard Dave 13 years ago
http://www.argos.co.uk/static/Product/partNumber/2830728/Trail/searchtext%3EDIVER.htm
lemonie 13 years ago
I like the enclosure you've done here, it looks very good.
L
