Cook Bacon in the Oven
Intro: Cook Bacon in the Oven
In this Instructable, I will show you how to cook bacon in the oven. This oven-baked bacon recipe is super easy to do and saves time if you are cooking lots of strips of bacon. Add a bit of brown sugar on top for some sweetness, you won't be sorry! If I can do it, you can do it. Let's get started!
Don't forget to follow me and check out my other Instructables :)
Follow the easy steps below or watch the short video tutorial or do both!
STEP 1: Ingredients and Tools
Ingredients:
- 6 slices of bacon (2 to 3 per person)
- 1 tsp Brown sugar per slice, optional
Tools:
- Sheet pan
- Parchment paper or silicone baking mat
- Tongs
- Paper towel
STEP 2: Prep That Bacon
Preheat the oven to 400F/205C, with the main rack in the middle position.
Line a sheet pan with parchment paper, a silicone baking mat, or aluminum foil. You can also just put the slices right on the pan, but cleanup isn't as easy.
Layout the strips of bacon on the pan, they can be fairly close together, which allows for several strips at once.
For a bit of sweetness (trust me, try this with at least a few slices) sprinkle on about a tsp or two of brown sugar on top of the slices. This is of course optional, but I like doing a few this way, it turns out so yummy.
NOTE: Some people put the bacon on top of an oven-safe wire rack which goes on top of the parchment paper and pan.
STEP 3: Cook That Bacon
Now place the pan of bacon in the oven and allow it to cook for 15 to 18 minutes until you have your desired crispiness. The thicker the cut of bacon the longer it will need, and of course the thinner the bacon the less time it will need.
If you have really thin bacon it may only need 13 to 15 minutes.
No need to turn it or anything while in the oven, just let it do its thing.
STEP 4: Dry That Bacon
Once the bacon comes out of the oven, let it sit for a few minutes. Then use tongs to remove it and place it on a paper towel. Pat the bacon dry, which will soak up the excess grease.
NOTE: You need to be careful with the brown sugar-coated bacon, just barely pat it, and DON'T let it sit on the paper towel it is sticky from the melted sugar and the paper towel will stick to it.
Time to serve that bacon. :) Enjoy!
STEP 5: Easy Cleanup
If you use parchment paper or foil, it allows for easy cleanup. You can also pour the excess grease into a can or mason jar and use it later, instead of throwing it out.
DON'T pour the bacon grease down the kitchen sink, haha.
Print the recipe here if you want.
2 Comments
DesertRick 2 years ago
In The Kitchen With Matt 2 years ago
