Introduction: Cool Canopy With LEDs for V939, or Ladybird Drone
This Instructable has been submitted to the "Make it glow" contest. If you like it, I'd really appreciate your votes.
How to make a cool canopy for your V939, Ladybird, etc., etc., drone.
A few months ago I bought a Wltoys V939, and while I like how the drone flies (you have to learn how to control it, because it's not super-stable), I disliked the way the canopy has been made.
So, not having a 3D printer, forced me to find another source, to find the "ideal" shape for the canopy.
Some people use the plastic bottle of the cleaning product, but I had the packaging of the disposable gloves around, therefore I opted for that one.
For this project you need:
The packaging of the Spontex disposable gloves
2x 3mm LEDS
2x 10K resistors
1 Syma batteries connectors (male/female)
Painting (possibly water based)
A rubber band
A set of propellers that match the color of the canopy
A soldering on iron station
Soldering wire and...
Patience!!!
Step 1: Buy the Spontex Disposable Gloves
Buy this...
http://www.ebay.co.uk/itm/like/321943416046?adgrou...
cut it (using carefully an utility knife).
Check that the length of the canopy, doesn't interefere with the propellers of your drone.
Step 2: Paint It... Red!
After painting it, make 2 holes 3mm (using carefully a small screwdriver).
Make another hole on the side of the canopy and (using carefully the scissor), cut a straight line on the other side of it.
Using a rubber band you can now put the canopy on/remove it from your drone, quickly!
Insert the LEDs inside the holes.
Step 3: Prepare the Connector... Aka Iron Soldering!
Solder to the short legs of the LED to a 10K resistor.
Buy this...
http://www.ebay.co.uk/itm/5-SETS-SYMA-X5C-X5A-X5SW...
and make the connector for the LEDs, checking the polarity.
You need to have 1 male connector that will go inside your pcb
and 1 female that will be connected to the battery.
Some batteries (Walkera) have the connector with the polarity inverted.
Please check it (twice) otherwise, you'll inevitably fry your pcb!!!
Buy also a set of propellers of the same colour of your canopy.
