Cool Matrix Infinite Number Batch Programming.
Intro: Cool Matrix Infinite Number Batch Programming.
I'm going to show you a step by step way to make an infinite random number stream. This is the final product:
STEP 1: Step One
First you have to open up a notepad file. (has to be empty) then type in @echo off
then you have to select your colors by typing 'color' then take the number and letter from this table and put it next to it:
0= black a= green
1= blue b= apua
2= green c= red
3= apua d= purple
4= red e= yellow
5= purple f= bright white
6= yellow
7= white
8= gray
9= light blue
0= black a= green
1= blue b= apua
2= green c= red
3= apua d= purple
4= red e= yellow
6= yellow
7= white
8= gray
9= light blue
STEP 2: Step Two
After the color command type:
:start
echo %random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%
(i recomend ctrl c then ctrl v'ing this about 14 times)
goto start
with this save the program as any thing you like (i'm using matrix programming) but has to have .bat at the end! i.e Matrix programming.bet and remember to save it to all files!
:start
goto start
STEP 3: Step Three
Go to your saves and double click on the program and it will launch it! should look like this:
12 Comments
ÍFSIN 5 years ago
MyticFlax 6 years ago
It's not working for me, I have done everything correctly and its not working it just doesnt start. Can I see a screenshot(s) of your notepad?
Matrix-technician 10 years ago
ɅܠΞܛ 7 years ago
have you tried putting it into a loop?
@echo off
:loop %random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%
goto loop
CravenMrrobob123 10 years ago
sorry for the late reply. To make it look right i suggest 14-15 %random% in it. the echo %random% should be on the same line btw. i hope this helped :)
You should have about 15 times but if you have put caps in the label (e.g :start) but didn't put caps in the goto (e.g goto start) then it will just end they both have to have caps or no caps in the exact place. But anyway this is the code:
@echo off
color 3b
:start
echo %random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%
goto start
Exept the %random%'s should all be on one line. Hope this helped.
P.s with help from Io kieran oI
mrroek 10 years ago
Not having any luck getting this to work.
Io kieran oI 10 years ago
at the end there is a slight typo were it says save as .bet when it should be .bat and makes sure that then you save, save it as a file type of All files. Also make sure the Echo %random%.... is on the same line. I hope I helped
mrroek 10 years ago
My mistake was not putting Echo and %random% in the same line. Works like it should now. Thanks!
YEAH! sorry! i will change
jgoewert 10 years ago
