Cop Car Camcorder Mount
Intro: Cop Car Camcorder Mount
Rig an onboard camera like the cops and NASCAR, for 15 bucks. Inspiration for this project from Make Volume 13. Mine adds a swivel mount that makes it much more useful. Enjoy!
STEP 1: What You Need...
1. 3/4" Square Aluminum stock tubing. About 2 Feet long
2. (2) "U" bolts with matching wing nuts
3. Dollar Store mini-tripod
4. 4mm 1 1/2" long bolt
STEP 2: Build the Mount
This mount installs on your headrest supports so you need to:
1. Measure across your headrest to in-between your seats.
2. Cut the aluminum tubing to that length.
3. Hold the cut tubing up to the headrest and make marks using the eyebolt where the bolt will go around the mounts.
4. Drill them with a bit larger than the eyebolt.
5. Drill a hole larger than the size of your bolt for the swizel mount.
STEP 3: Prepare the Swivel
Finding that Dollar Store mini-tripod was the score of the day! One screw removes the swivel section from the leg assembly and it's ready to install on our mount.
STEP 4: Final Steps
Run the 4mm bolt through the tube and screw it into the swivel mount. (Your screw size may be a different size based on the tripod you find)
Install the mount to your headrest supports using the eyebolts and the wingnuts. Install your camcorder to the swivel mount and you are ready to test it out! Have fun!
31 Comments
tripseven 15 years ago
AlSoto 11 years ago
tripseven 11 years ago
caitlinsdad 15 years ago
Jay$ 15 years ago
tonz0phun 14 years ago
nabzaf 13 years ago
nabzaf 13 years ago
CraigSnedeker 14 years ago
twocvbloke 15 years ago
RachaelSP 15 years ago
Instead of using that regular aluminum tubing, try out some of the 80/20 1" extrusion (part number 1010). With it you could simply adjust the bolts to fit various vehicles. They offer tons of various brackets and accessories, and you can make other non-80/20 stuff work as well.
Check out their site (http://www.8020.net/) for local dealers, or just go to McMaster-Carr (page 1888). McMaster doesnt carry all of their stuff though.
amakerguy 15 years ago
drsteevo 15 years ago
imshanedulong 15 years ago
Plasmana 15 years ago
codester 15 years ago
999592 15 years ago
jam3s 15 years ago
For a start, I didn't get the U Bolts, but two bolts with wing nuts and a mending plate was fine and still does the job.
Second of all, I didn't get the aluminum square tube, instead I got hold of an L shape aluminum piece of material. This does no where near have the strength to do the job properly.
When I put my DSLR onto it, it kinda bends and warps. It is strong enough to hold it, but it isn't strong enough to keep it in place whilst driving, so may result in fuzzy shots.
Great idea though =]
StrangeRover 15 years ago
