Copper Crystal Ring
Intro: Copper Crystal Ring
I made a ring earlier this year out of some scrap copper; it was terrible quality but it was fun to make. I decided to make another, higher quality, ring. I had read that copper can be made into crystals so I decided to grow some crystals and use them as the stone of the ring
This instructable was written late at night for a contest deadline so I have some steps I need to polish up
STEP 1: Items Needed
- sulfuric acid (battery acid)
- Copper
- 6 volt battery
- Plastic container
- Well-ventilated area
- Strong hammer
- Solid copper grounding wire
- Anvil/hard surface
- Sturdy vise
- Epoxy
- Sandpaper
- Rat tail and flat files
- Solder
- Propane torch
STEP 2: Growing Crystals
I found on the internet that if you put electrodes in sulfuric acid you can make copper sulfate and then crystals. I produced my Copper sulfate by suspending two copper electrodes in battery acid (dilute sulfuric acid) and running 6 volts DC through the electrodes. Overnight it turned blue (a sign it turned to copper sulfate.)
Though crystals can be formed by the method previously I actually ended up buying my copper sulfate as it was less time consuming and less dangerous. I heated up a kettle of water and dissolved some "Zep Root Kill" in a plastic container then let the water evaporate until nice crystals had formed
STEP 3: Making the Ring
I first took a 2 in. piece of the grounding wire and hammered it until it was about 2 3/4 in. Then I "rounded" it by rotating the piece while hammering. After it was approximately the circumference of my sisters' finger it broke it off of the rest of the copper wire. Then I started to bend it; by hammering and by bending it around a round piece of metal. It took a few pieces of copper to get the bending process correct so don't be surprised if it breaks in two.
STEP 4: Solder
After I test fitted it on my sister I cut some materia the ring with a Once I made sure that the ring fit on my sisters I decided to solder it together. First I got a piece of solder as long as the width of the ring. Then I used the blowtorch to melt the solder; since the ring is copper the solder wicked pretty nicely.
STEP 5: Polishing
Once I was satisfied with my soldering I started polishing the ring. I started sanding it with some high/medium grit with my hands but then I decided to put it on my wood lathe to speed the process up.
After a little bit I switched to a high grit emery paper.
STEP 6: Clear Coating
I affixed the crystal to the ring with epoxy on the opposite side of the lead joint.To protect the copper from oxidation I borrowed my sister's nail polish and clear coated the ring as well as the crystal because copper sulfate is slightly toxic and a mild irritant.
electronic_artist_ 6 years ago
