Cord Wrapped Handlebars (aka Rambo Style)
Intro: Cord Wrapped Handlebars (aka Rambo Style)
Alright, if Rambo rocked a 10 speed this is how he'd do his bars. This is also how he'd wrap his bars if he was on one of his daily Home Depot runs and got sidetracked in the rope section. I got this idea from the old school way of cord wrapping the ends of bar tape with string so I thought I'd give it a shot. It might be too hard for some people but hey, it only costs about $2 for the cord and you could always add some padding I suppose. Also, you can buy just about any color of electrical tape you could want.
STEP 1: Gather Your Supplies
All you really need is cord of some sort, electrical tape, and something to cut cord with.
STEP 2: Wrap the Bar With E-tape
Wrap the bars with electrical tape like a candy cane. Fold it over so that the sticky side is on both sides. This will hold the tape in place and keep the cord from slipping around on the bars.
STEP 3: Start Wrapping the Bars
You'll have to make a loop at the beginning so that the flapper goes up the bar and can be wrapped over, pull that loop nice and tight. Once you get a loop at the beginning you can begin wrapping evenly, make sure to keep some good tension on the cord and take your time to make it look pretty. Once you get to the end you'll want to do a similar loop and pull it as tight as you can. You can do a couple knots if you wish, then cut off the excess.
STEP 4: Finish Off the Ends
Put a plug in the end of the bars so that you don't take a core sample of your leg in a wreck. Then wrap some take on the ends of the cord wrapping. Stretch the tape super tight and don't skimp on the tape so it'll hold tight. Trim it up nice and good and you are ready to rock and roll.
STEP 5: The Finished Product
It probably won't look good on your $8k Cervelo but it might give your old beater a nice touch.
8 Comments
Wasagi 12 years ago
Calorie 14 years ago
I never wrapped handlebars with cord,. It might be a good substitute for the reversed electrical tape, or it could just augment it.
Interesting job. I like it.
cave12man 14 years ago
For the bar ends in the first pic, did you plug the ends and then use white electrical tape to cover the cord? Couldn't figure out how you got it so clean. Thanks for the idea!
russd32 14 years ago
duleonar 14 years ago
Here is a link from Rivendell on how to wrap using twine/rope.
http://www.rivbike.com/assets/payloads/108/original_twineforsite.pdf
They use it as an alternative to electrical tape, so if you used their method you wouldn't need any tape or anything to finish it off. I tried it on some bamboo for the garden, and it hold nicely.
fin saunders 14 years ago
For your 8K Cervelo, consider double constrictor knots to start/terminate the wraps.
http://en.wikipedia.org/wiki/Constrictor_knot
If you are using 100% cotton cord, if it's wet when you wrap, it will shrink when dry to further avoid loose wrapping.
Wrapping the electrical tape over the tucked under cord end at the start will hide the taping at the beginning of the wraps. This will also keep the cord from slipping off of the end of the handlebars.
I will definitely use this Instructible on my next handle-wrapping job.
Cheers,
Fin
toekneebullard 14 years ago
Good idea, looks snazzy.
