Introduction: Cordless Drill Rechargable LED Spotlight
I stripped the gearbox in my cordless drill that my mum gave me for xmas many years ago. I was going to throw it out but I couldn't bare to waste two perfectly good batteries. So I thought what can I do with them? Brainwave make a spotllight with a low voltage down light.
Step 1: Things That I Used.
Materials - Cordless Drill and accessories
Low voltage Downlight kit
LED Downlight
Tools - Soldering Iron
Solder
Screwdriver
Wire strippers or Pliers
Electrical Tape
1hr of your time
LED Downlight
Solder
Screwdriver
Electrical Tape
1hr of your time
Step 2: Disassemble Cordless Drill Casing
Important - Remove battery from drill before disassemble.
remove all screws and pull housings apart carefully
Step 3: Remove Drive Motor and Chuck Assembley
Cut the two wires going to the drive motor as close as you can to the drive motor. Remove drive motor and chuck assembley carefully and put them aside for another project.
Step 4: Strip and Prepare Wire Connections
cut the downlight connector cable from your downlight kit to the correct length. Leave an inch or two extra. strip and twist all four wires ready for soldering.
Step 5: Solder Wires and Wrap Each Wire With Electrical Tape
Step 6: Check for Fit
Check the fit of the downlight globe. Modify housing with a dremmel if required. and use hot glue if needed.
Put wires nicely in place being careful not to pinch them between the two covers.
Step 7: Reassemble and Test.
The 3 watt led downlight globe works great. I did test it also with the halogen 50 watt downlight as well and you can vary the brightness using the trigger. I think I will stick with the LED because battery life is substantially improved about 12 hours before i have to change the battery. You can change the polarity using the forward/reverse switch. The LED globe worked in both positions. I will try a dimmable led next time i go to the hardware store.
and best off all it comes with a carry case and a spare battery. Thx mum.
