CoronaVirus Killer With Arduino Nano and UV Light
Intro: CoronaVirus Killer With Arduino Nano and UV Light
According to the latest guideline on the diagnosis and treatment of the novel coronavirus released by the National Health Commission, the virus is sensitive to ultraviolet light and heat, so ultraviolet radiation can effectively eliminate the virus.
The problem with ultraviolet light is that it irritates the skin and increases the chances of getting skin cancer.
Precisely for this reason, through an Arduino Nano and some sensors and transducers, we can create a PCB capable of controlling a UV lamp to cause it to kill the virus without, however, turning it on with ourselves in the vicinity. In this way we will protect our skin.
STEP 1: Theory Behin the UV Light
To kill the virus in closed spaces, we need a lamp of at least 1.5W per square meter. If left for at least half an hour, it will kill all viruses within a meter of you.
Specifically, if the temperature is less than 20 C or greater than 40 C or the relative humidity is greater than 60% we should keep the lamp on for longer. Although UV is effective in killing the virus indoors, UV lamps should not be used to sterilize hands or other areas of skin, as the radiation can cause skin irritation.
STEP 2: Draw the Electric Scheme
In the Scheme we need an Arduino Nano (any Arduino is fine), a DHT11 temperature and humidity sensor, a buzzer, a relay, a diode, two terminal blocks and a power supply to power Arduino, transforming the 220Vac into 12vdc.
STEP 3: Build the PCB
We arrange the components so that they take up as little space as possible in the PCB and order it.
I have also attached the BOM to the steps.
STEP 4: Write the Code
Next you will need to upload the code to arduino. With the start button we start the cycle and arduino will keep the lamp on for half an hour if the temperature and humidity is optimal, otherwise for a whole hour.
pressing stop returns to the initial condition.
STEP 5: Conclusion
Now with this PCB we can sterilize environments.
Remember not to expose yourself to contact with ultraviolet lamps because they can cause skin irritation.
I do not take any responsibility for my project, it is for illustrative purposes only.
14 Comments
Rose Li 3 years ago
jalilel1913 4 years ago
Is there a BOM available for this project? Also, where can I find a company that can make the PCB Board? I work in a healthcare setting and I think this would be a great secondary environmental services measure.
MicheleMeattini 4 years ago
electronic_artist_ 4 years ago
Mammacita509 4 years ago
https://blog.arduino.cc/2020/03/27/together-lets-make-covid-19-history/
rafununu 4 years ago
If UV can cure and destroy the virus, don't you think government agencies would have largely spread UV lamps to chicken producers, hospitals and public places. Who cares of cancer when lives are threatened ? Only some UV frequencies can drive to a skin cancer, not all the spectrum. The sun light contains a lot of UVs, so stay naked outside to be safe !
JohnMitchell4 4 years ago
Did you read the article? "Specifically, if the temperature is less than 20 C or greater than 40 C or the relative humidity is greater than 60% we should keep the lamp on for longer. Although UV is effective in killing the virus indoors, UV lamps should not be used to sterilize hands or other areas of skin, as the radiation can cause skin irritation."
Second: https://lmgtfy.com/?q=uv+lamp+to+kill+covid+ This method is used in various cities and hospitals.
sfc5112003 4 years ago
but i feel you will be able to kill germs with UV light but you can kill virus with UV? You cant kill a virus but it might go in hibernation kind of ...may be
viruses have RNA right? how you will kill them.....
psyfect 4 years ago
This could be implemented most everywhere; especially government based areas, children based (daycare with x+ amount of children) and strongly encouraged for all other facilities.
A novel approach would be to add this as an additional function to current bulbs so that by day it can illuminate and by night it can clean; including smart settings to ensure an empty room (motion activated lights/thermal/etc.) when activating.
Everywhere from huge places like Walmart (activated in zones; since they are 24 hours) to homes with smart light bulb technology (to activate while away from home and in rooms with no pets).
Mickey The Maker 4 years ago
