Country Pottery Kickwheel
Intro: Country Pottery Kickwheel
Build a old fashioned rotary flywheel Pottery Kickwheel for about 100$
After a lot of searching on the internt, I could not find a decent drawing of a console style kickwheel for making pottery. so I made one. Measured drawings included...
STEP 1: Building the Base Frame and Seatposts
Using standard dimensional lumber (2x4) the build begins with the back and floor frame.
STEP 2: Front Frame and Seat Supports
adding the front frame and the seat supports
STEP 3: The Adjustable Seat
the adjustabel seat is made of 2 (or 3) 2x4's attached with 7 inch peices of 2x4
STEP 4: Adding Frame Peices
additiional peices are attached to the frame.
STEP 5: Drawing Out the Flywheel
drawing the 31.5 inch disks from a peice of 8x4 plywood.
this is a cheap trick, fit you have a center hole drilled, just poke a hole in a peice of cardboard , measure out the radius, poke another hole there, and use it like a disposable compass
STEP 6: Cutting the Flywheel Top and Bottom
you will need to cut 2 31.5 inch disks from plywood. save all the scrap (see measured drawing)
use a circular saw to split the plywood into 2 4x4 sections, then cut the disks out with a jigsaw.
STEP 7: Flywheel Cuts
you should have 2 flywheel dosks and 4 half moon shaped peices of plywood.
(only one shown)
drill a 1 in hole on the center of the disks, and attach the 1in floor flanges to the disks.
(only one shown)
STEP 8: Weighting the Flywheel
using constuction adhesive, glue the bricks t the bottom flywheel disks.
STEP 9: Finishing the Flywheel
using more constuction adhesive, glue the top of the flywheel down and weight down.
imusing a 1 inch hoe handle to aligh the disks while they are drying.
STEP 10: Bolting the Flywheel to the Base
after temprarily removing the base boards, the flang bearing is attached to the flywheel with a 3 inch pipe nipple.
STEP 11: Flywheel Installation
the flywheel is slid into place and secured with screws
STEP 12: Wheel Head Shaft and Support
the wheel head shaft is a peice of 29 inch galvanized pipe. the 1 5/.16 pillow block is driven on, and secured with a top frame support
STEP 13: Completing the Wheel
more freame peices are cut, the leftover plywood is fit into place to secure the console.
the wheel head is another 10 inch disk cut from the same sheet of plywood. alternatovle, you could but a ready made aluminium disk, or use a cake pan full of plaster...
STEP 14: Moose and the Infernal Machine
A very tired moose relaxes with his new construction
nothing left but painting...
STEP 15: Measured Drawings
this is a set of ikea style measued drawing and material list.
if you have any questions ytou can contact me on facebook at Moosestudiospottery
STEP 16: Measured Drawings
the following include the build drawings.
53 Comments
AbsolutCorrupt 3 years ago
AnnaJ3 8 years ago
Hi Moose! I'm very thankful for these plans. I've been reading and re-reading to try to make sure I understand everything. On step 10 does the 3" pipe nipple need to be threaded on both sides? I'm asking because I believe a pipe nipple is usually threaded on both ends, but the blow-up drawing of the flywheel construction does not show threads on both ends.
Also, since you made this a number of years ago, I'd be very interested to know if it's still working for you, or if it wore out or became unusable?
AnthonyH223 3 years ago
ellawhiteford 3 years ago
Gomi Romi 11 years ago
Ohregano 4 years ago
deshelman 5 years ago
ShaunC23 5 years ago
unher 5 years ago
Hi from Japan! Sorry if I missed the information, but I am wondering if the wheel rests on the floor, or just on the bottom support. In other words, how far off the floor does the wheel sit? Thank you for your kind advice.
MadisonL10 7 years ago
MaryS191 8 years ago
Thank you for sharing this fantastic Instruction for building a pottery kickwheel!
Its been a wonderful help!
bkoch4 8 years ago
bkoch4 8 years ago
colton_554@msn.com
karacolor 13 years ago
Thank you for the great instructions!
Moose Gueydan 12 years ago
I also have pending drawigns for a plate display rack, Bottle shelves, 5 gallon bucket shelves, a plate and tile drying case and finaly a motor for the kickwheel
Samitpatel76 9 years ago
jerryo13 10 years ago
Thanks
Jerry O.
sing1ejack 12 years ago
I'm also wondering what kind of shop I might look for locally (VT) to find a good metal wheel head?
Thanks for putting this instructable up - I'm thoroughly inspired!
