Cover It. Timer With Vibrating Alarm (TfCD)
Intro: Cover It. Timer With Vibrating Alarm (TfCD)
As a prototype for a wearable we have made a bracelet with a timer and a vibrating alarm. the alarm can be turned off by covering a LDR sensor. The idea behind this prototype is that it can be integrated in a (smart)watch. Initially the idea was to deactivate the alarm with an accelerometer, shaking the arm would have turned off the alarm. With no accelerometer at hand a LDR was used to show the principle and interaction. This instructable was inspired by other instructables.
STEP 1: Step 1: Components
For this prototype the following components are used:
- Arduino (in this case Duemilanove but uno or another arduino would also work)
- Breadboard
- 7 segment display
- LDR
- Transistor P2N2222A
- DC Motor
- Diode 1N4148
- 4,7 KOhm resistor
- 3x 220 Ohm resistors
- Jumper wires
STEP 2: Step 2: Assembly
Assemble the components as shown in the picture. when you extend the wires of the LDR and motor you can place them on a bracelet.
The 7 segment display is connected as follows
- a = pin 2
- b = pin 3
- c = pin 4
- d = pin 5
- e = pin 6
- f = pin 8
- g = pin 9
One of the COM pins should be connected to the ground via a 220 Ohm resistor and the other COM pin should be connected to the VCC also via a 220Ohm resistor.
the 3rd 220 Ohm resistor is used for the motor.
and the 4,7 KOhm resistor is for the LDR.
STEP 3: Step 3: Programming
Copy the following Code to Arduino:
int a = 2; //For displaying segment "a"
int b = 3; //For displaying segment "b"
int c = 4; //For displaying segment "c"
int d = 5; //For displaying segment "d"
int e = 6; //For displaying segment "e"
int f = 8; //For displaying segment "f"
int g = 9; //For displaying segment "g"
int LDR = A0; //LDR
int LDRValue = 0;
int tril = 12; // motor
void setup() {
pinMode(a, OUTPUT); //A
pinMode(b, OUTPUT); //B
pinMode(c, OUTPUT); //C
pinMode(d, OUTPUT); //D
pinMode(e, OUTPUT); //E
pinMode(f, OUTPUT); //F
pinMode(g, OUTPUT); //G
pinMode(LDR,INPUT); //LDR
pinMode(tril,OUTPUT); //motor
Serial.begin(9600);
void displayDigit(int digit) {
//Conditions for displaying segment a
if(digit!=1 && digit != 4)
digitalWrite(a,HIGH);
//Conditions for displaying segment b
if(digit != 5 && digit != 6)
digitalWrite(b,HIGH);
//Conditions for displaying segment c
if(digit !=2)
digitalWrite(c,HIGH);
//Conditions for displaying segment d
if(digit != 1 && digit !=4 && digit !=7)
digitalWrite(d,HIGH);
//Conditions for displaying segment e
if(digit !=1 && digit !=3 && digit !=4 && digit!=5 && digit!=7 && digit!=9)
digitalWrite(e,HIGH);
//Conditions for displaying segment f
if(digit != 1 && digit !=2 && digit!=3 && digit !=7)
digitalWrite(f,HIGH);
if (digit!=0 && digit!=1 && digit !=7)
digitalWrite(g,HIGH); }
void turnOff() {
digitalWrite(a,LOW);
digitalWrite(b,LOW);
digitalWrite(c,LOW);
digitalWrite(d,LOW);
digitalWrite(e,LOW);
digitalWrite(f,LOW);
digitalWrite(g,LOW); }
void loop() { LDRValue = analogRead(LDR);
int i;
for( i=9;i>0;i--) { displayDigit(i); delay(1000); turnOff();
if (i <= 3)
digitalWrite(tril,LOW);
else digitalWrite(tril,HIGH);
Serial.println(LDRValue);
if (LDRValue < 500)
digitalWrite(tril,HIGH); } } }
Open the Serial Monitor to check the values of the LDR, to define the threshold that fits your environment, adjust "if (LDRValue < 500)" to your threshold.
STEP 4: Step 4: Testing
The motor starts vibrating when the countdown reaches 3 and when the LDR is covered the motor stops again.
3 Comments
Miaevaaaaa 5 years ago
DIY Hacks and How Tos 8 years ago
Great alarm design.
