Create Your Own VR Game Controller Using Arduino
Intro: Create Your Own VR Game Controller Using Arduino
If you are a gamer and a hardware geek at the same time, you obviously know how hard it can be to choose how to spend weekend, playing games or making cool hardware. This project will give you heaven of the both worlds!
We will create an Arduino based game controller which detects motion which works as a great controller for VR games. But it's not limited to VR, it can be used to play any supported PC, XBox or PlayStation game.
Required Hardware:
- Arduino Uno
- MPU6050
STEP 1: Programming Arduino
If you are not interested in details how the program works then simply upload the code given in resources.zip to Arduino Uno and jump to Step 2.
_
Initializing SensorTo initialize the sensor, we first initialize the I2C communication using standard Wire library then configure the MPU. If configuration fails, then the Arduino goes in forever while loop as it’s useless to continue.
void InitializeMpu() { Wire.begin(); Wire.setClock(400000UL); i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode while (i2cRead(0x75, i2cData, 1)); if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register Serial.print(F("Error reading sensor")); while (1); } }Reading the Motion Data
Motion data is read from IMU sensor (MPU6050) in every loop and the respective gyro and accelerometer values are updated. The following function does this job.
void UpdateReadings() { while (i2cRead(0x3B, i2cData, 14)); accX = ((i2cData[0] << 8) | i2cData[1]); accY = ((i2cData[2] << 8) | i2cData[3]); accZ = ((i2cData[4] << 8) | i2cData[5]); tempRaw = (i2cData[6] << 8) | i2cData[7]; gyroX = (i2cData[8] << 8) | i2cData[9]; gyroY = (i2cData[10] << 8) | i2cData[11]; gyroZ = (i2cData[12] << 8) | i2cData[13]; }Computing Angles Using Complementary Filter
Angles can be computed using complementary filter with a good accuracy. We will use complementary filter since it’s fine for most of the application. But if you need even better accuracy, you can use Kalman Filter.
void ComputeAngles() { double roll = atan2(accY, accZ) * RAD_TO_DEG; double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG; double gyroXrate = gyroX / 131.0; // Convert to deg/s double gyroYrate = gyroY / 131.0; // Convert to deg/s compAngleX = 0.98 * (compAngleX + gyroXrate * dt) + 0.02 * roll; // Calculate the angle using a Complimentary filter compAngleY = 0.98 * (compAngleY + gyroYrate * dt) + 0.02 * pitch; }Set Controller Data Object
We need a dataForController_t object to send data to the computer/host as a joystick. We use the following code to create and fill dataForController_t object.
dataForController_t getControllerData(double _roll, double _pitch) { //Restrict roll and pitch to +-90 if (_roll > 90 || _roll < -90) _roll = 90 * _roll / abs(_roll); if (_pitch > 90 || _pitch < -90) _pitch = 90 * _pitch / abs(_pitch); //Get new instance with default values of buttons and sticks dataForController_t controllerData = getBlankDataForController(); controllerData.rightStickX = (int)(_roll * 1.42 + 128); controllerData.rightStickY = (int)(_pitch * 1.42 + 128); //You can use these and many other buttons also // controllerData.triangleOn = !digitalRead(2); // controllerData.circleOn = !digitalRead(3); // controllerData.squareOn = !digitalRead(4); // controllerData.crossOn = !digitalRead(5); return controllerData; }
In loop() we will call this function as,
dataForController_t controllerData = getControllerData(compAngleX, compAngleY);Send Controller Data to Computer
To send this data to joystick simple call the setControllerData() function as follows,
setControllerData(controllerData);
STEP 2: Connect the MPU Sensor
Connect the MPU sensor with Arduino Uno as,
Arduino MPU6050
3.3V ————- Vcc
Gnd ————- Gnd
A5 ————— SCL
A4 ————— SDA
After you have programmed your Arduino Uno with the given code, connect the MPU. You can uncomment the following line to check on serial monitor/plotter if everything is working fine, moving the sensor will change the values accordingly. Be sure to comment it again after testing.
//#define DEBUG
STEP 3: Turn Arduino Into Joystick
To turn Arduino into joystick first you need to turn start Arduino into DFU mode. To do this, just connect the pins mentioned in the image.
On Windows the Arduino (usb device) will disconnect with a sound (be-dun). And connect again (buh-din!). Now Arduino is on DFU mode, just open the TurnIntoAJoystick.bat file (see resources section) and it will turn your Arduino into a joystick.Atmel FLIP must be installed for this to work. In windows 10 go to Settings > Devices > Connected Devices and it will show up as a Joystick.
STEP 4: Testing the Joystick
You can test the joystick using TestJoystick.exe (see resources section). Just connect the Arduino Joystick into your computer and run TestJoystick.exe. It will show a floating plane that rotates as you move the joysytick. You can add more buttons and features and use it the way you like. For more information check out the UnoJoy page.
If it works fine then go ahead and try it with your favorite games!
26 Comments
Marionf 6 weeks ago
Thanks for sharing the project, but I can't connect the controller with Steam VR, since it doesn't give me any option to pair it or anything. How can I do it?
Skyflamme 2 years ago
Marionf 7 weeks ago
How can i connect it to Steam VR?
Ceiling light 7 weeks ago
yes its great, its better with 2 if you can get it right.
Ceiling light 4 months ago
Hello and thank you very much- it was hard to do at first but i got it in the end.
I want to ask, How can i get the temperature readings off the mpu6050 aswell and render it, Do you think it will need a seperate widget?
Always learning
G
Hassaan Akbar 7 weeks ago
Source code already contains tempRaw variable. This is the formula to convert it to degrees,
Temperature in degrees C = (TEMP_OUT Register Value as a signed quantity)/340 + 36.53
Thank you, I did find it, I started making a tkinter widget and got stuck with the serial protocol as I didn't have the device with me.
Will try again in the morning, I'm using this device to control a motion driving simulator. Thank you again for making this possible,
It is too sensitive for the motion driving simulator I made, also with Arduino ( could double as electri car)
I also used it on quake and it's just too sensitive.
Please help.
Thank you
waia_game 2 years ago
Hassaan Akbar 2 years ago
https://github.com/AlanChatham/UnoJoy
thanks again for the help, I'll try another library :)
in your opinion, is it possible to set the throttle using 1 of the 3 axis?
Ahmet Hamdi 3 years ago
I Couldn't find it
Hassaan Akbar 3 years ago
https://www.instructables.com/Blink-Your-First-Arduino-Project/
aaditya k 3 years ago
great project btw, keep up the good work
https://github.com/HassaanAkbar/VRGameController/blob/511e34a9d215797a7c480cc0fe2850ffee50208e/VRGameController/VRGameController.ino#L142
wetekkplay82 3 years ago
