Create a Simple Python Text Editor!
Intro: Create a Simple Python Text Editor!
In this Instructable I will be teaching you how to create a simple text editor with Python and the module Tkinter.
To do this tutorial you need some basic knowledge of Python.
First create a python file called texteditor.py or something like that. Then open it with a text editor like Atom or Notepad ++.
STEP 1: Making a Window
To make a text editor we need a window. Type in the file:
import sys
v=sys.python_version
if "2.7" in v:
from Tkinter import *
elif "3.3" in v or "3.4" in v:
from tkinter import *
root=Tk("Text Editor")
root.mainloop()
Then if you are on a mac go Cmd+Shift - search and open "terminal" - then type
python /pathto/texteditor.py
and hit enter.
If you are on a windows, search and open Command prompt, type
and hit enter. You should se a screen that looks like the picture above.
Congrats!
STEP 2: Add a Text Widget
Now we need to add something to type in.
Underneath root=Tk() add two lines like this:
text=Text(root)
text.grid()
Then run the file again like in step one. You should get a bigger screen with a text box in it when you click on it. It will look like the picture above.
Your full code will look like this now:
import sys v=sys.version()
if "2.7" in v:
text=Text(root)
text.grid()
root.mainloop()
STEP 3: Saving Your Text
You need to be able to save your text of course, so we will add a button to save.
Under import Tkinter add
import tkFileDialog
and under import tkinter add
import tkinter.tkFileDialog
Under the last line you added write this:
def saveas(): global text
t = text.get("1.0", "end-1c")
savelocation=tkFileDialog.asksaveasfilename()
file1=open(savelocation, "w+")
file1.write(t)
file1.close()
button=Button(root, text="Save", command=saveas)
button.grid()
Clicking on the button will save your file.
The full code:
if "2.7" in v:
from Tkinter import * import tkFileDialog
from tkinter import * import tkinter.tkFileDialog
root=Tk("Text Editor") text=Text(root)
text.grid()
def saveas():
global text
file1.write(t)
file1.close()
button.grid()
root.mainloop()
STEP 4: Font Changer
Under the last line you added, add this:
def FontHelvetica():
global text
text.config(font="Helvetica")
def FontCourier():
global text
text.config(font="Courier")
font=Menubutton(root, text="Font")
font.grid()
font.menu=Menu(font, tearoff=0)
font["menu"]=font.menu
helvetica=IntVar()
courier=IntVar()
font.menu.add_checkbutton(label="Courier", variable=courier,
command=FontCourier)
font.menu.add_checkbutton(label="Helvetica", variable=helvetica,
command=FontHelvetica)
Congratulations! You have finished a very simple text editor. If you want more tutorials like this tell me what here.
Run the file to use it!
Full Code:
import sys
v=sys.version()
if "2.7" in v:
import tkFileDialog
text=Text(root)
text.grid()
def saveas():
global text
file1.write(t)
file1.close()
button.grid()
global text
def FontCourier():
global text
font.grid()
Helvetica=IntVar()
arial=IntVar()
times=IntVar()
Courier=IntVar()
font.menu.add_checkbutton(label="Courier", variable=Courier,
root.mainloop()
27 Comments
nasingfaund 2 years ago
try:
except ImportError:
try:
import tkFileDialog
except ImportError:
import tkinter.filedialog as tkFileDialog
###v=sys.version()
'''v=sys.version_info
if "2.7" in v:
import tkFileDialog
import tkinter.tkFileDialog'''
text=Text(root)
text.grid()
def saveas():
global text
file1.write(t)
file1.close()
button.grid()
global text
def FontCourier():
global text
font.grid()
Helvetica=IntVar()
arial=IntVar()
times=IntVar()
Courier=IntVar()
'''font.menu.add_checkbutton(label="Helvetica", variable=helvetica,
command=FontHelvetica)'''
root.mainloop()
this code work on Py3.8 07.07.2022
arthursiq5 2 years ago
This is my code:
import tkinter
def saveas():
global text
savelocation = tkinter.filedialog.asksaveasfilename()
file=open(savelocation, "w+")
file.write(t)
file.close()
global text
def FontCourier():
global text
root = tkinter.Tk()
text = tkinter.Text(root)
text.grid()
button = tkinter.Button(root, text='Save', command=saveas)
button.grid()
font=tkinter.Menubutton(root, text="Font")
font.grid()
font.menu=tkinter.Menu(font, tearoff=0)
helvetica=tkinter.IntVar()
courier=tkinter.IntVar()
root.mainloop()
Dimlu 5 years ago
This whole thing is broken for python 3. I will say, this is a great learning tool for an intro into this. Here's what I got:
import os
from tkinter.filedialog import askopenfilename
text=Text(root)
text.grid()
def saveas():
global text
file1.write(t)
file1.close()
button.grid()
global text
def FontCourier():
global text
font.grid()
Helvetica=IntVar()
arial=IntVar()
times=IntVar()
Courier=IntVar()
font.menu.add_checkbutton(label="Helvetica", variable=Helvetica,
root.mainloop()
DJMoffinz 2 years ago
Using Python 3.9 :)
akmnos22 5 years ago
samuelopemipo006 3 years ago
Name error: TK is not defined
jariuscaden 3 years ago
import Tkinter as TK
bahramit324 3 years ago
jesteraexy 4 years ago
aaronliu0130 5 years ago
But one more thing:
How do you show all the fonts in the system?
aruba246 6 years ago
Ineedaname87 6 years ago
When I run that command in the terminal at the start to make the window, it comes up with this. python: can't open file ' /pathto/texteditor.py': [Errno 2] No such file or directory.
PLS HELP! I am running this on windows 7. I have installed Python 3.6.5 and I'm using the Atom text editor.
Ben4jammin2 5 years ago
KonstantinosA16 5 years ago
vungtau 5 years ago
Thanks.
The first thing is that line 4,
v=sys.version()
sys.version is an string and not a function that will return a string
also the command to run the program and make the window is for mac only.
I hope this answered all these questions.
If my answers don't make sense I'm sorry I'm an newbie to tkinter
akhildabraal 6 years ago
Hi Sir/Mam,
I was checking out your code can you tell me how can I add a check box in front of the text box as I am planning to make it as a ToDo List Application.
mcovic 6 years ago
Can you make a tutorial that teaches how to add syntax highlighting? (For IDE's)
