Create a Virtual Wifi Network Using Command Prompt on Windows 10
Intro: Create a Virtual Wifi Network Using Command Prompt on Windows 10
STEP 1: Start Menu
1. First, go to the start menu on your computer.
STEP 2: Password
Enter a password if asked (if you’re not on an
administrative account).
STEP 3: Command Prompt
Search for the command prompt application (cmd).
STEP 4: Administrator Account
Second, right click and select run as administrator
STEP 5: First Command
Third, type the following command to see if your
computer supports hosted network: “NETSH WLAN SHOW DRIVERS”.
STEP 6: Support for Your Computer
If you see a “Yes” that means your computer does
support hosted network and “No” if it does not support hosted network.
STEP 7: Setting Up the Network
Type the following command prompt: NETSH WLAN SET
HOSTEDNETWORK mode=allow ssid=Network key=passphrase and press enter. *Make sure you replace the “network name with the name you want to use and the “key” with the password of your choice.
STEP 8: Start HOSTEDNETWORK
Type NETSH WLAN START HOSTEDNETWORK and press enter.
This will turn on the hosted network.
STEP 9: Stop HOSTEDNETWORK
Type NETSH WLAN STOP HOSTEDNETWORK to turn the
hostednetwork off.
STEP 10: Close Window
After you are finished exit out of the command prompt
windows.
8 Comments
flubbywubkins 3 years ago
Not sure if I should proceed, since I’m not confident in compatibility. EVEN THOUGHT windows 10 has a section in the action center for hot spot, and I’ve made a network name and pass which showed up on other devices but eventually once connected would say “no internet connection”. Assured my Pc is connected at this point :/
“Hosted group could not be started. The group or resource is not in the correct state to preform the requested operation”
Obviously not your fault but why does windows add a box in the “action center” for wireless hotspot connects (up to 8), if it’s not supported in my system and there’s no way to upgrade to have the capability included ?
OctaviousUalr 6 years ago
Whenever you create your hosted network it will automatically save for you to re-use whenever you want to. Just type the command netsh wlan start hostednetwork and it will turn on when using the command prompt.
Commands are not case sensitive, so they can be typed in either upper or lower case letters.
Penolopy Bulnick 6 years ago
Nice job with your first Instructable!
