Create Your Own Y-Parametric Table - More Artistic Furnishings!
Intro: Create Your Own Y-Parametric Table - More Artistic Furnishings!
This is my second single sheet plywood furniture instructable! If you missed the first, the Fishbone chair, please check it out! This too I made at the Techshop!
This was another instance of me scouring through the internet late at night, and saw something that caught my eye! A piece by Krystian Kwiecinski that was beautiful in form and function, and it inspired me to create my own design. I don't know why she called it parametric, but the name represented the idea of creating curves and contours through equations to me. So it sounded cool as well.
I think it was more the unique physics in play that grabbed my attention, but I thought it was worth trying out the good ole 3D design program again to see if my own creation would work.
It took me about 6 hours of 3D designing, sans sanity breaks, to get out these initial designs put together, but I was entertained by figuring out how to make the mini-animation
STEP 1: Components
A little creative twist to update to my basic component forms, and I have what I think are some pretty good plans.
Basically, all you need is to get the leg, the support triangle, and the pegs set. The tabletop is pretty easy once you know the basics.
I cut down the dimensions of this piece to less than a single sheet (Half Sheet!!!!), mainly because I didn't need a full sized table, so I set it at about coffee table height, and only about 4 feet long
STEP 2: Cut and Finish!
STEP 3: Final Results!
At home to do a little fine sanding, and a dry test fit.
I left it outdoors overnight and the feral cats that seem to love my backyard for some reason, decided to walk all over it. :-(
A quick linseed oil coat to protect and highlight the natural grain is the only step after this dry fit.
And.... VIOLA!!!
A designer table!
One thing to note is that I do not use any screws, nails, or glues. This is all slotted furniture for easy assembly and awesome looks!
Enjoy!
And.... VIOLA!!!
A designer table!
Enjoy!
23 Comments
weisner1 7 years ago
This is beautiful work, a really great job. I am considering doing this in steel using 1/4" sheet steel. Thank you for the inspiration.
ohmdaddy 7 years ago
Thank you. I would really like to see how the steel version turns out. Are you planning on using a waterjet, cnc, or cut by hand?
m3d1973 10 years ago
ohmdaddy 10 years ago
hsartoris 10 years ago
Lord Maul 10 years ago
>> FreeRiotPoints.me <<
WayneEarl 10 years ago
bakunin 10 years ago
They are indeed very awesome.
http://www.tapplastics.com/
ToolboxGuy 10 years ago
If you put together/take apart a number of times, do the joints still hold well? Some designs get a bit of wear on the tabs, and it goes from knock-down table to firewood....
I knew i would have a slight difference in height. Also, I made all the measurements to fit precisely so it would be tight. I can pick up the whole table and nothing wiggles or falls out. I imagine that a bit of sanding could make it a bit looser.
One thing that I would note is that you would likely want to loosen the fittings if you are going to stain or coat the wood. You will get a bit of swelling
shallnot 10 years ago
Well, form Kwieciński's site you linked to we find "Y parametric table was designed to be easily customized and rapidly fabricated. Through the m3dify web page, customers can modify the dimensions, geometry and materials of the table to fit their specific requirements and preferences."
Seems to answer your implied why question.
myronf48 10 years ago
thanks
Breygon 10 years ago
pbel 10 years ago
bryanbrews 10 years ago
