Introduction: Created by Thunder Laser.How to Make a Trojan Horse?
To make a wooden horse, the design drawing is very important, we can design the wooden horse according to the user of characteristics. Firstly, measure the user's height, then draw up a blueprint, which can add some original elements, For example, for children, we can add some interesting small animal patterns.
Step 1: Bill of Materials:
A laser cutter: Nova35(80wat)
plywood
Step 2: Setting Parameters:
Processing Mode: cut
Speed: 20mm/s
Max power: 60%
Min power: 70%
After we design the file in CorelDraw, we send the file to laser software directly by clicking the laser plug-in. Then we input the best setting parameters and “Download” the file to the laser cutter.
Step 3: Start Cutting:
Place the wood sheet on the machine working table, move the laser head to the right start position, adjust the focal distance, press “Origin” button to set the starting point, then press “Start” to run the job.
Step 4: Assemble(finished):
After the laser cutter finish working, Assembly is
the most important part of make the wooden horse, it will not only test your proficiency, but also test your ability to assemble. This step requires us have mind with no arrogant and rash to assemble.
The magic weapon of the successful assemble are the patience and the mind with no arrogant and rash. Firstly, we can assemble a general framework, and then assemble other parts in detail.
Step 5: Work Show:
A wooden horse is a very special toy, its design concept is relatively
humanized, to ensure the safety of children and to give children a comfortable experience. The wooden horse made by laser cutting machine has been finished, let’s making a wooden horse by ourselves and regaining good of your childhood!
3 Comments
4 years ago
Hello
Thank you for sharing this beautiful project! This is wonderful work!
Could you share the design file? As Shadshaun, my son would love this!
Question 5 years ago on Step 3
This is fantastic! Would you be kind enough to share the design file? My son would love this!
Answer 5 years ago
Hi,thank you for your fancy,because the Chinese New Year,we just came back to work,I have sent the file for you,please check it,thank you.
