Creating Your First Program in Visual Basic
Intro: Creating Your First Program in Visual Basic
This instructable will show you how to program Microsoft Visual Basic 2005 Express Edition. The example that you will create today is a simple image viewer.
If you like this instructable please push the + button at the top of the instructable. Thanks.
Also, I think I will be like half the other instructables out there and say that this is my first instructable and please don't be to harsh.
EDIT: Once you have completed this instructable, continue learning VB with my second Visual Basic Instructable: Creating a Program in Visual Basic: Web Browser
STEP 1: Download Visual Basic
You can download visual basic 2008 from microsoft but this instructable is specificly for VB 2005 wich you can download from freeware files
EDIT: It is now recommended you VB 2008, as I will use it for any future tutorials. Link
Please note: you will still need to be connected to the internet during the install.
STEP 2: Create Your Project.
Click File->New Project. Select "Windows Application". Give your project a name.
STEP 3: Add Controls
From the tools box, drag a picture box onto your form, drag a button onto your form and drag an open file dialog onto your form.
STEP 4: Edit Control Properties
Now it's time to edit the properties of the controls. To edit properties, click on the object and change the values in the properties window.
Form Properties
Form Properties
- Text: Picture Viewer
- Form Border Style: Fixed Tool Window
- Background Image Layout: Zoom
- Text: Select Image
STEP 5: Add Code
Double click on the button and replace all the text in the code window with the following:
Begin Code
WHAT THE CODE DOES
Public Class Form1 - Defines the form as Public
Private pic As Bitmap - Defines pic As a private bitmap
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click - Defines When The Events Should Occur
OpenFileDialog1.FileName = "Select File" - Makes the file name in the OpenFileDialog say Select File
OpenFileDialog1.ShowDialog() - Shows the OpenFileDialog
pic = New Bitmap(OpenFileDialog1.FileName) - Adds the value of the selected image to pic
PictureBox1.BackgroundImage = pic - Changes the image in ImageBox1 to pic
End Sub
End Class
Begin Code
Public Class Form1 Private pic As Bitmap Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click OpenFileDialog1.FileName = "Select File" OpenFileDialog1.ShowDialog() pic = New Bitmap(OpenFileDialog1.FileName) PictureBox1.BackgroundImage = pic End SubEnd ClassEnd Code
WHAT THE CODE DOES
End Sub
End Class
STEP 6: Save and Test
Save your program (File->Save All) and click the green play button on the toolbar to debug your program. If all goes well then you should be able to use the program.
The final program is stored in 'My Documents/Visual Studio 2005/Projects/PROJECT NAME/PROJECT NAME/Bin/Debug/PROJECT NAME.exe'
(Where PROJECT NAME is the name of the project)
STEP 7: Final Thoughts
That's it!
Congratulations on creating your very first program in visual basic. It wasn't so hard now - was it?
Now you can go onto making more complex programs, or you can edit this one. I made some modifications to my program:
- I changed the background color
- I added some copyright info
- HINT: You do it using the properties window.
50 Comments
waterlubber 12 years ago
BTY Figured out had do to that auto size thing. set size to AutoSize. Easy. Same with copy right.
Use this:
MessageBox.Show("YOUR MESSAGE HERE")
That puts a pop-up!
megatjt 13 years ago
http://en.kioskea.net/download/download-104-visual-basic-express-edition
Fox-san48 13 years ago
Colonel88 14 years ago
munchman 14 years ago
Rockerx 15 years ago
munchman 15 years ago
awang8 15 years ago
replacing filenamehere with the name of your audio file (don't write .wav). Repeat for each button. You should now have about a hundred errors. Now, to fix those errors go to Project - Properties and click on the resources tab. Click add resource and select your file. Repeat for every song. All errors should disappear. Now debug your program and check to see if it works.
If it does: Hooray! You're finished. Now publish it and install.
If it doesn't: Make sure you done everything correctly. If it still doesn't work, get a hammer and smash your "I won't work for you" computer.
animan1 14 years ago
awang8 15 years ago
ReCreate 14 years ago
