Credit Card Ipod Stand
Intro: Credit Card Ipod Stand
Hey guys this is my first instruct able thingy hope you like it
If you don't have an ihome or any of those other fancy gadgets this is the next best thing at making your phone or iPod feel cozy and safe
List of needed items:
Two credit or gift cards(if you using a credit card make sure you cut in such a way that people won't be able to get you information cause that would not be good) in this case I'm using two iTunes gift cards
Something to cut the cards with, scissors, xacto knife, or dremmel
A marker to draw your outline
Tape or hot glue
Tape or hot glue
STEP 1: Drawing the Outline
Draw your outline of where you wanna cut your shape(don't be afraid to be creative) and double check before you begin cutting the card
STEP 2: Cutting the Card
Follow the outline drawn with your knife or other cutting tool you choose to use, the xacto blade was taking longer than I had hoped so I cut a groove with the knife and followed it with the scissors
Once I cut the piece off I cleaned it up a bit by burning the frayed stuff off with a lighter then bumped it with a little bit of sand paper
STEP 3: Cutting the Other Card
Just use the other card you just finished as a template,( keep in mind this one a mirror image of the first one)
STEP 4: Adding "padding"
(This step is optional)
Once you finish cutting the last card out its time for padding
To keep from scratching my ipod(and to cover up my horrible cutting and burning job) I added some electrical tape around the edges
Note: there are other things you can use, like cloth or leather or something
First cut a piece of tape slightly longer than the over all length that the tape will be cove
Place the center of the tape on the edge of the card, (I've found it easiest to put it in my finger and press it into the curved part first,)
Then once you make sure it's all straight cut a slit on each side of the tape where the curve is so you are able to fold the tape over each side
Once you fold the tape over, trim off the excess tape
Repeat for the second card
STEP 5: Putting It All Together
Once you've finished padding the cards it's time to put them both together
Cut a piece of tape just long enough to where the card starts to curve so you done have any exposed sticky stuff
If any of the tape sticks out just trim with a blade
Put the cards back to back and place the tap, make sure it's straight
I'd recommend putting another piece on the other side but you don't have to if you don't like the look of it
STEP 6: All Done!!!
Once it is finished it can be folded up and put in your wallet and it can hold your iPod up in a horizontal and vertical position
Haha I was using my iPod to make this so I used a symphony bar to model it instead and I apologize for any typos that I'm sure I've made
Thanks for checking this out hope you have fun don't be afraid to experiment with this. Stay cool guys :)
