Custom 3d Printed Car Parts
Intro: Custom 3d Printed Car Parts
The ability of 3d printing to form any shape is quite remarkable. To be able to imagine a part, design it and then simply place an order online and have it arrive in the mailbox is amazing. Especially when the part in question could not realistically be made any other way.
Take for example these lock levers from my 1962 Valiant. The originals are a diecast aluminium and feature a very fine spline. I doubt they would be able to be manufactured any other way. Even with CNC machining I imagine the part would have to be made in two pieces if it was possible at all.
The replacements were needed due to an oversight on my part. I had made some lovely new door trims for my the Valiant. The fronts turned out so well i went ahead and made the rears to match. However in my enthusiasm I did not take into account the lock levers which only feature on the rears. Show here is the locking lever spline protruding through the trim baseboard before trim, and after I had finished the trim with the padding. No spline protrudes and therefore the original lock levers do not fit. So how to fix this without remaking the whole door trims?
3D printing to the rescue!
STEP 1: Measure
Carefully measuring the spline dimensions gave me the basics. A 20 spline shaft with an outer diameter of 8.29mm and an inner diameter of 8.08mm, a length of 12mm and a spline depth of only .2mm. This would surely be stretching the the limits of 3d printing accuracy, but I had been very happy with shapeways SLS fine detail on some previous models, so I thought it would be worth a shot.
STEP 2: Modelling the Critical Details
To the modelling. I am using modo because it is what I am competent in - a dedicated CAD program would be much better no doubt, but the principles should apply to all 3D packages.
Starting with the critical details first, in this case the splined section, I made a cylinder of the inner spline dimension. A key point here is that the cylinder had 80 sides. This allowed my to select every 4th side and scale from the centre point to the outside spline dimension. This forms the basic spline shape.
STEP 3: Finish Modelling
From there I fine-tuned the inner and outer ends of the spline as needed, and then made the rest of the lever model around it. Taking into account the fact it needed to me about 10mm longer to clear the new door trim. I also made the base quite wide to cover the hole through the trim and was able to form the countersunk screw hole on one end of the splined section. The basic shape of the lever was supposed to be based off the main door latch handle so the style kinds of matches.
STEP 4: Upload and Order the Design
After a few hours of tweaking the design I uploaded the model to Shapeways. I had to save it out a few times to make sure it uploaded in the correct dimensions, but once I was sure it was correct I ordered 2 in black strong and flexible and waited for the postman.
STEP 5: Install Parts
A few weeks later my nicely bubble wrapped levers arrived and I went straight out to test them. To my slight amazement and immense relief, the splines came out perfectly, and they slid straight onto the shafts in the doors. My diligence in measuring everything paid off and I now have some custom door lock levers, and didn't have to modify my nice new door trims. Initially I was intending to order them in stainless steel, however the plastic ones seem to be perfectly strong enough, so unless they break I will stick with them.
Now, what to build next...
16 Comments
3dcarmods 8 years ago
Our website is all about that. We plan to 3D scan OEM parts that can be modified and 3D printed. Some parts can be plastic but others must be stronger. Thanksfully, you can use 3D printing to create yourself a MOLD. With that mold, you can do carbon fiber parts or do metal parts with a cold casting method :
If a part doesnt exist, we can design/3D print it for you. New features are coming every week.
www.3Dcarmods.com
MichaelW146 8 years ago
Finding auto parts is frustrating when you don't want to pay the full price, sometimes I wish I could just create the parts myself. It sounds like you actually used a 3D printer to make your own car parts. How did that would out for you, did it work and how did you know the machine would make the exact measurements? <a href='http://www.alliedauto.ca' > http://www.alliedauto.ca</a>
Melia Esperas 9 years ago
EasyHomeConcepts 9 years ago
Wow, that's awesome.
madmorrie 10 years ago
I had intended to get metal ones printed and then polish them, but I will see how the plastic ones hold up to general usage first. They seem pretty strong to me.
And yes, while this is a relatively simple part, it does show the opportunites for this kind of thing. This was still way cheaper, faster and easier than most options than cnc or manual machining.
XenonJohn 10 years ago
About to print some HT lead spacers for my 1968 VE Valiant using my Makerbot. I probably have the only one in the UK (Valiant that is).
John
loop 10 years ago
justajo 10 years ago
dodgedartgt 10 years ago
onemoroni1 10 years ago
maxo90 10 years ago
monkeyracing 10 years ago
This could also have been accomplished by a machine shop using a broaching tool. The tradeoff would be expense, but the result would be a very strong part.
Aloxite 10 years ago
liquidhandwash 10 years ago
jarikcbol 10 years ago
