Custom Long Board
Intro: Custom Long Board
In this project I spent about 40$ without the trucks, bearings, (just the board)
It´s an easy project if you know the basics of wood working and how to use fiber glass, even if you don´t know how to use them its no that difficult.
I'll try to explain each step by step, unfortunately I couldn't take some pics when i was working with the fiber and the resin 'cause I had my hands full of fibers, anyways...
STEP 1: Materials and Equipment
I used pine and mahogany veneer because they where the cheapest I could found, but you can use what ever you want:
- 2 sheets of mahogany triplay (I used 40cm x 110 cm x 2.7mm)
- 1 sheet of pine veneer ( I used 40 cm x 220 x 1 mm)
- 1 kg of glass fiber (aprox)
- 750 gr of polyester resin
Adhesive grip (30cm x 160 cm)
- 1 brush (any size, to apply the resin)
- 1 dremel or moto tool
- Masking tape, or duct tape
- Scale
- Plastic recipients
- Latex gloves
- Security glasses
- Overall or lab coat
- Saw band
- Drill
Polishing hand machine
- Wide belt sanding machine
STEP 2: Design, Veneer
First of all the design I made it in Rhinoceros a cad program and printed them to make an stencil, you can do the same or trace it by hand
- In the mahogany triplay trace the silhouette of the skate
- Cut it in the band saw a few millimeters offset
- With the band sand it
- Copy the first form in the other triplay
- Attach them and cut them with the saw band
- Sand them
STEP 3: Glass Fiber, Resin and Veneer
CAUTION, glass fiber really irritates skin, eyes, nostrils and the whole body, I recommend you to use an overall or lab coat, latex gloves, and safety glasses every time. (I used two latex gloves for each hand, because they always break)
- Cut the fiber a few inches longer and wider than the board
- Try to separate the fiber making at least 2 sheets from each one
RESIN
- Put some resin in your bowl about 300gr will be ok
- Mix it with the catalyzer (mine used 2%-3%)
- Stir for 30 seconds or until they mix together
- Apply a thin coat of resin over the triplay with the brush, then a sheet of fiber, then resin, then veneer like this:
TRIPLAY |RESIN |FIBER |RESIN |VENEER |RESIN |FIBER |RESIN |TRIPLAY - Then apply some weight over the sandwich you made ( I used some wood and 3 buckets )
- Let it cure
STEP 4: Cutting
It will take about 2 -3 hours to cure, but I let it cure for the night instead just to be sure...
- Cut the surplus of the fiber and veneer with the band saw
- Sand it
- Dremel the surplus
- Sand it with the hand polisher
STEP 5: Cover
- With masking tape make a fence around the deck
- Apply some wood sealer
- Apply 150 gr of resin (I used the same of the fiber, but I think that a crystal resin will make it better)
- Wait to cure
- Apply the design, I made some sticker Hawaiian flowers ( you can use serigraphy, vinyl stickers, or anything you want)
- Apply another coat of resin 50 gr will be ok
- Let it cure
STEP 6: Grip and Trucks
Grip
Unfortunately the wider grip I could find was 30 cm, my longboard wide is 34 cm -.-
- Cut the grip surplussing the edges about 1 cm more
- Add the missing spots
- With a key or a wrench press the edges of the long board over the grip
- Cut the surpluses
Trucks
- Mark with pencil the holes for the trucks
- With a bench drill make the holes
- Add the trucks with the wheels
STEP 7: Ready to Hit the Roads
I loved the strength of the glass fiber with the mahogany, but for the next one I´ll use walnut because it's stronger
Maybe apply some carbon fiber for some details.
I'll appreciate your comments
