Customizable 3D Printed Ring Designs
Intro: Customizable 3D Printed Ring Designs
I designed and created 5 ring shapes and, in this Instructable, show you how to customize them in 123D. Even if you're like me and don't have a 3D printer, you can still customize your own ring shape and in a few clicks, send your design off to be printed. I've included all five designs for you to download and customize. There are STL files attached and links to the models pages in the 123D Gallery.
STEP 1: The Files You'll Need
Here are the rings and I've numbered them 1-5. You can download the files here. I've attached STL files and also included hyperlinks below so you can download straight into 123D and start customizing your ring right away!
I'll be using ring design #5 to show you how to personalize it with your initials.
Free 123D Download
Ring #1:
Ring #2:
Ring #3:
Ring #4:
Ring #5:
Free 123D Download
Ring #1:
Ring #2:
Ring #3:
Ring #4:
Ring #5:
STEP 2: This Is What We're Making
This is the finished ring that I personalized using the Ring #5 design from the previous step. In the following steps, I'll show you how to customize your own ring. This technique can be used to personalize the rings in many different ways. In step 15, you'll see another example of how to use this technique.
STEP 3: Open 123D
After downloading 123D, open the file.
STEP 4: Open Ring #5 File
Click the 123Design logo in the left hand corner. Click on the OPEN button. Select the BROWSE MY COMPUTER tab and open the downloaded file.
STEP 5: Ring #5 Is Opened
Now you'll see the ring on your screen.
STEP 6: Open Primitives Menu
Midway down the screen, on the right hand side, you'll see a long grey tab with a white arrow inside. Click on the white arrow to display the Smart Primitives menu.
STEP 7: Inserting Text Box
Under the Smart Primitives menu to the right, select and drag the top box, which is titled TEXT, on to the work surface and you'll see the text appear.
STEP 8: Customizing Your Initials
With the text box selected, at the bottom of the screen, you will see a long white tool bar. The text box will automatically have 123Design. Delete this text and replace with your initials.
STEP 9: Adjusting the Angle of the Text
The text is facing the wrong way, so click on the white disk that is on the same plane as the text. A box will pop up so you can change the degree. Enter 90 in the box and press ENTER.
STEP 10: Putting Initials on Ring Surface
First, click on the tool in the upper tool bar called the SNAP tool, it looks like a magnet. This will snap the initials into place on the ring. Second, change your perspective so that you're looking at the initials from underneath. Select the underside of the middle initial. Now, use your mouse to change perspective so that you can see the top of your ring. Click on the top of the ring so that the initials snap into place.
Note #1: If you select the top of your initial, instead of the underneath, it will flip the text over. The snap tool puts the two selected surfaces together, no matter their direction.
Note #2: Often, when you snap the two objects together, they form a group. This basically means when you're trying to select one object, both will be highlighted. To separate the objects, simply click on the GROUPING button on the top tool bar and select UNGROUP.
STEP 11: Resizing the Text
In the top right hand corner, there is a directional cube. Click on TOP. Now select the text. To resize the text, select the button at the bottom that says SCALE. Then, drag the arrow to resize the text so that it fits on the ring.
STEP 12: Adding Depth to the Text
Click on the text. Select the SCALE button at the bottom of the screen. Click on the only drop down menu and change it from UNIFORM to NON-UNIFORM.
In the Z axis, change the number to 15 and press ENTER.
STEP 13: Making the Split
Deselect the objects (click off them). Now, hover over the MODIFY button from the top menu bar. Select the SPLIT SOLID button on the far right in that menu. Click on the ring. Now click on SPLITTING ENTITY from the double menu that pops up. Click on the initials and press ENTER.
STEP 14: Hollowing Out the Ring
Select the initials and press DELETE on your keyboard. Now select the initials on the surface of the ring and press DELETE again to expose the void and there you go! Well done, your ring is ready to 3D print. If you want to have your ring printed, then Autodesk makes it simple...you can click SAVE from the main menu and select TO MY PROJECTS. Now your ring is in the 123D Gallery and you can get it printed there!
Note: I made the ring to be the average woman's ring size, which is 7. If you'd like to change this, you can scale the ring to your desired specifications using the scaling tool that I've shown in previous steps.
STEP 15: Endless Possibilities
Simply by using shapes instead of text, I made this ring. You can do the same with all of the ring designs to customize a gift for yourself or your special someone.
9 Comments
murat.bilginsoy.5 9 years ago
hey everyone :) so i downloaded ring #5 and all the necessary software to put my initials on it but unfortunately 123D does not recognize the ring as a solid. This means that I can not SNAP, MODIFY, etc. The software always tells me to select a solid or a surface but I can not select the ring. Please help, thank you :)
mattgrieve 10 years ago
jacopogio 10 years ago
Can you confirm me that you got those rings shown in the photography above out of a Makerbot replicator 2 ?
And what is the superb material that you used to get that "translucent glass like look"
Best
Jac
huating 10 years ago
steventrotter 10 years ago
chetancc 10 years ago
rjh1 10 years ago
I have a Makerbot replicator 2 but I have only had it for about 1 week. I am very impressed with its quality and it is very easy to use. It is not the cheapest one but I think it is a good balance between price and quality.
If you are not in a rush I would wait unit 2014. There are a number of 3D printing patents that are going to expire at the end of the year which will see a lot of new printers hitting the market which should mean they will drop in price. This is a short article about the patents - http://www.designboom.com/technology/3d-printing-patents-expiring-in-2014-will-see-market-erupt/.
I hope this is helpful.
joe19 10 years ago
rjh1 10 years ago
