Customize Your PCB Shape With Easy Steps (Full Beginner Toutorial)
Intro: Customize Your PCB Shape With Easy Steps (Full Beginner Toutorial)
This PCB will be slightly different from other PCBs so Keep Reading carefully
The Component I need
In this tutorial, you will learn various skills that will make up your PCB design skills
This tutorial is meant for beginners and intermediate, we will go through a lot of things so keep attention
STEP 1: PCB Design
open KiCAd
Strat to add Fab modules library
Start to add the Components we need
Check the Connections and see if there is an Erorr or not
After that Open Fusion 360 Draw the Shape you like And then Save It as a DXF file
Import the DXF shape to KiCad to make the Connection of the Circuit Inside our shape
Then Export the Gerper Files
Then after that take the two output images
then Open FAB MODULES
Then Upload the Top layer and choose the output (for me it's role and mill)
Then Choose the PCB Traces (1/64)
Then make your Preferences and Press Calculate
then Send it to the machine
and then make the same thing in the outline
STEP 2: Soldering the PCB
STEP 3: Embedded Programming
There will be a full tutorial on Embedded programming on Embedded C
Stay tuned for this Tutorial
