Customize Your Lip Gloss
Intro: Customize Your Lip Gloss
an easy way to personalize your lip gloss :D
STEP 1: You Will Need:
-a bead or pendant
-a tube of lip gloss
-a short chain
-a clasp
-two jump loops
-a thick pin
-pliers(or some thing else to make the hole bigger with with)
-a short chain
-a clasp
-two jump loops
-a thick pin
STEP 2: Making the Chain:
Firstly you will need to add the bead or pendant i have used a bear pendant. You can do this by using a jump loop.Open the jump loop by twisting it with your pliers. Then inset the chain and pendant/bead. Close the jump loop by twisting it with your pliers again. To add the clasp you must repeat this at the other end of the chain.
STEP 3: Making the Hole in the Lip Gloss:
At first use a pin to make a small hole in the end of the lip gloss tube. Then use the pliers to make the hole bigger been careful not to tear the edge.This is were to attach the clasp.
STEP 4: Finished
Attach the clasp to the end of the lip gloss and you are finished :D
shaniyabeck 7 years ago
it was not enught information
