Introduction: Cute Concrete Planter
These cute concrete planters are an adorable addition to any home or garden! The molds are made of recyclable materials and concrete mix is very inexpensive to buy. You can switch up the plants in these planters to give these little guys a fresh new 'do.
Step 1: Gather Your Supplies
To make the mold, you will need:
- Plastic pop bottle
- Marker
- Scissors and utility knife
- Tape
- Drinking straw
- Cooking spray or petroleum jelly (as a mold release)
To mix and cast concrete, you will need:
- Concrete mix
- Safety gear: gloves, mask, safety glasses
- Container for mixing
- Water
- Something to mix with (eg. garden trowel)
To add the finishing touches, you will need:
- Concrete paint
- Paintbrush
- Coconut fiber or potting soil
- Plants
Step 2: Cut Pieces for Your Mold
You will want to use the upper portion of the plastic pop bottle. Mark where you want your cutting lines to be on your bottle. (Tip for drawing perfectly straight lines: Use a metal clip to hold on to your marker and stick the clip to a magnet on your refrigerator. Then place your bottle so that it is touching the fridge and position the marker so that it is in contact with the bottle. Rotate the bottle all the way around so that you have drawn a line all the way around the bottle.)
To cut the bottle, I first used a utility knife to make a puncture and then I continued with scissors. Once the dome part is cut out, you can work on the inner cavity. You will need to cut a strip from the bottle that is about a half an inch shallower than the dome part
Step 3: Assemble Your Mold
Roll up the strip of cut plastic and place it in the opening at the top of the dome. Let the strip unroll so that it forms a cylinder the same size as the opening. Tape it in place.
Use tape to close the inner tube cylinder at the end that is closest to the large end of the dome. Make a hole in the tape and stick a straw through to make a drain hole.
Coat the mold with cooking spray or petroleum jelly to help the concrete release.
Step 4: Mix & Cast Concrete
I used about 4 pounds of mix for 3 planters and used the amount of water suggested by the instructions. I mixed it in a plastic bucket with a garden trowel. I added the mix to the mold, a little bit at a time, while tapping the mold to try to prevent air pockets. Remember to wear your gloves, mask, and safety glasses!
I cured the concrete for the amount of time the instructions suggested for warmer weather. During this time, I tried to keep the concrete moist. After I removed the concrete from the molds, I soaked the planters in water and vinegar overnight to try and neutralize the concrete.
The bottom of my planters were not completely level, so I sanded them down using a bit of sand and a plank of wood.
Step 5: Finish
Paint on a face with paint suitable paint for concrete.
Fill the planter with coconut fiber or potting soil and add a plant hairdo.
Done!
Runner Up in the
Concrete & Casting Contest
Summer #mikehacks Contest
5 People Made This Project!
- swaggydude made it!
- alyssa.hays made it!
- TrueGeek68 made it!
- Akin Yildiz made it!
See 1 More
69 Comments
Question 3 months ago
How Did You Make This??? I Want To make It, But The Steps Are Confusing. Help!
Question 1 year ago
Hi there. I am trying to work on making one of these as a gift! But I’m having a little trouble following the instructions along with the pictures on assembling the mold. I can’t understand how to tape the pieces together and how far deep to place the strip of plastic. Is there a video maybe that goes along with this? Thanks!!
2 years ago
So.Stinkin.Cute.
I need this
Tip 3 years ago on Step 2
Add tip...
3 years ago
I LOVE IT. It's so CUTE how did you get that cute idea.
4 years ago
SOOOOOOOOOOOOOOOOOOOOO CUUUUUUUUUUUUUUUUUUUUTE
5 years ago
Those are ADORABLE!
5 years ago on Introduction
omg these little guys are sooooooooo cute
(ɔ◔‿◔)ɔ ♥
Great idea these look adorable!
5 years ago
Hi, I tried making planters and a week or 2 later they all developed slight cracks in them, do you think maybe because I sealed the pot 3 days after and should I wait 2 weeks?
6 years ago on Introduction
The things someone can do with concrete are amazing. I recently tried something like this and uloaded an instructable. I went for a bigger planter though.
Very Good!
cute :)
6 years ago
:D sooooo cute!!
Congratulations on being a finalist in the Concrete and
casting contest! Best of luck to you!
love these happy face cement planters
Reply 6 years ago on Introduction
Thanks! :)
What happy faces, and your choice of 'do' is very cute.
Thank you!
Awesome Cute ..
