Introduction: Cylinder Shaped Leather Bag
I don´t have that much leather tools but still enough to have them messed up in my tool case. I figured out that something have to do. I decided to make cylinder shaped leather bag for my hole punches.
Materials
- leather, I used 1,8 mm thick veg tanned leather( leftover from knife sheath projects.)
- metal zipper
- waxed thread for leather
- leather balsam
Tools
- knife
- ruler
- glue
- stiching punch tools
- hole punch
- needles
- stamping tool
Step 1: Cutting
Cut rectangle and two round blocks. Use template or draw measurements on the leather. measure twice and cut once. (My measurements 23 cm x 12 cm)
Cut hole for zipper. I punched round edges at the end.
Step 2: Preparations
Stamping logo: Moisten leather and stamp logo on it. I used wax stamp and vise to add some pressure. Few minutes and its done.
Dye: If you are going to dye your leather, then this is good time to do it. I wanted my leather to be natural this time. Sunlight, age and dirty hands will do the patina
Edge burnish: Burnish edges with wood block or use rotary tool and suitable burnisher for it. In my project I used beeswax and oak block for burnishing.
Leather glue: Glueing zipper in place helps you sewing because you won´t have to worry about zipper not lining up correctly.
Prepare leather for sewing: Mark guideline for holes. I used ruler and draw slight mark on the leather with needle. Punch holes
Step 3: Put All Together
Prepare 1 thread with 2 needles.
First sew zipper with saddle stitch. Secure with back stitches at the end.
After the zipper is done bend leather and join edges. Baseball stitch is very decorative stitch to join edges. I secured sewing with two knots
Sew top and bottom. I used saddle stitch wich is very strong and also beautiful if it runs straight and consistent. Make sure that you pull thread tight enough. Finish with back stitches.
Finished with leather balsam and its done.
Tandy Leather Contest 2016
3 Comments
6 years ago
What should be changed if I want to make this with 2 mm Pleather?
Reply 6 years ago
no need to change anything. I used 1,8mm thick leather.
7 years ago
This is great. I really like the baseball look that it has.
