Introduction: DANCING LED WITHOUT ANY IC,CAPACITOR OR TRANSISTOR
HI FRIENDSSSSS.....
This project work on simple LED series cuircit
BUT Tri colur led blinks it self which allows the current to pass on its own oscillation as a result the whole LED series show dancing effect .
Hope you like it.
(((((((((IF YOU LIKED IT COMMENT FAST OR IF YOU DIDN'T UNDERSTOOD ANY STEP ASK ME IN COMMENTS)))))))
Step 1: THINGS TO BE NEEDED
For this awsome project you will need
3 led(Tri colour led (recommended) blue and green (optional) .).
Bread Board.
9 v battery.
Battery holder
Note: you should have Tri colour Led as without this you can not build this project
Step 2: CIRCUIT DIAGRAM
On the basis of the same circuit diagram we will be constructing our project
Step 3: FIRST STEP
Take your circuit board and check each hole of it so that no problem occur in future in making the circuit
Step 4: INSERTING FIRST LED
Insert the blue LED in one of the hole of circuit board
Step 5: INSERTING SECOND LED
Insert the Tri colour LED in the circuit board and insert +ve terminal of Tri colour LED to the -ve terminal of blue LED
Step 6: INSERTING THIRD AND THE LAST LED
Now insert the green LED in the circuit board and connect the +ve end of green LED to the -ve terminal of Tri colour LED
By completing these steps you will be having +ve terminal of blue LED and -ve terminal of green LED
Step 7: CONNECTING BATTERY HOLDER'S WIRE TO THE CIRCUIT
Connect the +ve (red wire) to the +ve terminal of blue LED and -ve (black wire) to the -ve terminal of green LED
Step 8: PROVIDING POWER TO THE CIRCUIT
Now connect the Battery to battery holder
Step 9: RESULT
You will be having the dancing LED without using any IC OR CAPACITORS OR EVEN ANY TRANSISTORS
Step 10:
http://m.youtube.com/watch?v=QjiJgSN1uDo
15 Comments
2 years ago
how come is it possible. Will u please explain the principle
8 years ago on Introduction
Awesome but i will beat you at school just wait :P
ohhh archit bhai aap kaise................................ how was my instrtuctable.
8 years ago
Technically you use the ic that is inside the tri-colour led
8 years ago
click on the link to see vedio or search on youtube "DANCING LED WITHOUT IC OR CAPACITORS"
8 years ago
http://m.youtube.com/watch?feature=em-upload_owner&v=QjiJgSN1uDo&desktop_uri=%2Fwatch%3Fv%3DQjiJgSN1uDo%26feature%3Dem-upload_owner#
8 years ago
First buy Tri colour Led and then make the circuit and then see if it works. BUT I will be uploading the video soon Because I don't know how to upload video here so I will be uploading vedio on YOUTUBE and provide you all the hyperlink of that vedio
8 years ago
In Led series circuit the current is flowing continuesly so the whole series glow but not blinks BUT here the main work is of TRI COLOUR LED because it blinks itself to produce the three different colours
Sorry. I don't understand the principle of this circuit. How could three leds on series to blink? Tri colour LED means leds with different colour or TGB led? The simplest way is to show us a movie. Thanks!
8 years ago
No not nessesary
8 years ago
Is a tri color led in essence just a RGB led?
8 years ago
No the Tricolour LED blinks itself which allows the current to pass on its own oscillation on which the Tri colour LED itself is blinking as a result the whole line gets blink like a dancing effect due to oscillatory current which is flowing
8 years ago
there are only 3 led in paralel this should light up all at once
8 years ago
so has any body made this yet
but if done right with caps u could make self powered 4 a few mins.
